High-Pitched Whining Sound
would almost bet is the power steering resorvoir. i had very similar symptoms. just had the resorvoir changed at the dealership at a tune of $1k. not covered under cpo. there is currently a technical bulliten out by porsche regarding this issue. a technical bulliten is not a recall. good luck
I have a 2003 with the same whine - but only very sporatically. Would the cost of replacement be assumed by the dealer?
RFL - I also live in Westchester. Which dealer did you use?
He uses Pepe, as do I. But I'm never thrilled with their service (they're just very convenient for me). Who do you use and do you like? GBG
I bought my car at Pepe.
I use Prestige in Palisades for service. I like there service dept. One of their men tracks his own car. They are 'mod friendly'. They know of my chipping of the car and have done warranty work without a problem.
I was wondering if the repair of the power steering fluid reservoir would be covered under warranty for a 2003 car.
Guess I'll post this in this thread too...
Just got our car back from the dealer, they replaced the power steering pump. By the time I got home (closest dealer is 1+ hours away), the whining was back. When I push the clutch in the TONE of the whine changes but it doesn't stop.
What's wrong now? I called and they said they are going to contact Porsche to see what else can cause it.
They replaced:
Power Steering Pump
P/S O Ring x 2
P/S Bracket
CHF 202 (?)
They claim the car is safe to drive with the new pump but it is still whining loudly (I think only when it is warmed up)... Any ideas?
They replaced:
Power Steering Pump
P/S O Ring x 2
P/S Bracket
CHF 202 (?)
They replaced:
Power Steering Pump
P/S O Ring x 2
P/S Bracket
CHF 202 (?)
They replaced:
Power Steering Pump
P/S O Ring x 2
P/S Bracket
CHF 202 (?)
Scott, when this issue first surfaced a couple of years ago, I recall others getting the pump replaced and still having the whine...I remember because I was glad it worked for me. Perhaps search the old threads to see what they did.
Did they replace your accumulator which is located on the clutch slave cylinder?
"cause: as per bulletin 1/05-4897-4
48971906 expansion tank removed and reinstalled
997-314-920-30 AS steer. oil tank
000-043-206-56 Pentosin CHF202 (1 L)"
Hey Guys....Is this the sound you are dscribing or am i looking at a different issue??
I got no power assist what so ever. It spits the fluid out and the sound is a bit lower pitched than on the video. It is a 2002 911 turbo tiptronic.
http://www.youtube.com/watch?v=1ax73nuVVws
http://www.youtube.com/watch?v=Mt4J4DEJQzM
