996 Turbo Forum 1999-2005
Spoiler Failure 996TT
Old 06-07-2007, 01:23 PM
r34dy2walk
r34dy2walk's Avatar
Default Spoiler Failure 996TT
okay so i just got back from iraq and picked up my 996 TT.
i love the car.... driving max speed of 60mph in a humvee made this car scary to drive lol..
anywho, apparently my battery died and it seems like my "spoiler failure" light popped on. i can manually raise it and lower it but this annoying failure light is making my "emaculate" porsche into a "HJLKJ$@)()JD)AJ GO AWAY LIGHT".
the nearest porsche dealership is hundreds of miles away so if i can i want to try to fix this myself.
someone told me that it might be a dirty sensor or maybe it just needs to be lubed... im completely clueless. again, it goes up and down manually but when i hit 75mph or 37mph it wont automatically do its thing and pops failure light at me..
Old 06-07-2007, 01:44 PM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
This is a known problem. A search (rear spoiler failure) will yield about a dozen threads detailing it.
It can be the instrument gauge cluster, the actuator assembly, etc.
IIRC, there was a TSB but never a recall generated for this.
Best of luck and Welcome Home
Old 06-07-2007, 01:50 PM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
Old 06-07-2007, 05:00 PM
99firehawk
99firehawk's Avatar
probnaly needs siwtchs pul tohe cover on the pass side rear cylinder and inpsect the switchs or the spoiler for sighns of leakage
Old 06-07-2007, 05:20 PM
Wachuko
Professor of Pending Projects
Wachuko's Avatar
Cool
Spoiler warning light comes on: Faults found 9150. Replaced spoiler motor/drive assembly - Part No. 996-512-241-02 (spoiler drive). Spoiler drive was a grey area in terms of warranty coverage... but covered under original warranty as a good will gesture since the car had recently come out of original warranty and into CPO...
Old 06-07-2007, 05:34 PM
alpha1
alpha1's Avatar
My similar issue solved by a new gauge cluster, replaced under CPO.
Old 06-08-2007, 01:16 AM
Cueto
Cueto's Avatar
WHHOOOOAAAAA new Guage Cluster?
I just started recieving this same error. The spoiler goes up and down perfect, full extension/retraction at the right times/speeds even with the switch.
I sure hope it isn't a new Cluster since unlike you guys i am out of warranty and no CPO down here (Puerto Rico)
Old 06-08-2007, 09:53 AM
r34dy2walk
r34dy2walk's Avatar
im kinda in the same boat.
ive searched the archieves only to find out its either the motor, cleaning, or the gauge cluster...
the warranty on the car expires while i was overseas...
Old 06-08-2007, 10:12 AM
Wachuko
Wachuko's Avatar
Cool
Do check with the dealer... depending on how long ago the warranty expired you might be able to get them to cover it under goodwill... never hurts to give it a try.
Best of luck... and let us know what they find and how this turns out.
Old 06-08-2007, 12:21 PM
r34dy2walk
r34dy2walk's Avatar
that wont be until i get back to new york... ::sigh:: oh wells, at least i still have all my limbs to enjoy the car.
Old 06-09-2007, 03:41 AM
kglesq
kglesq's Avatar
"oh wells, at least i still have all my limbs to enjoy the car."
Well, when you look at it from that perspective, ANY problem with the car seems pretty minor. Enjoy the car--you've clearly earned it.
Old 06-09-2007, 01:48 PM
porschedude996TT
porschedude996TT's Avatar
Welcome back from Iraq, and thanks for you service to our country.
Old 06-12-2007, 11:27 PM
rbcsaver
rbcsaver's Avatar
Welcome home and thank you for serving. Hope you resolve your spoiler problem easily.
regards,
Steve
Old 06-15-2007, 08:06 PM
Garey Cooper
Garey Cooper's Avatar
If the car sat for a long time I'd try this; at rest manually raise the spoiler, using the cleanest cloth you have clean the riser tube. Then manually drop it. I'd further cycle it several times manually (I mean using the switch on the console). I'm hoping for your sake the thing maybe just picked up some dirt/dust in/on or around the riser and that cycling and cleaning it will get rid of this and get all of the seals etc. to remember how to behave. Give it a try, better than having to go further on the repair.
I'll add my thanks for your service as well, you have my admiration and respect.
Old 07-06-2007, 07:28 AM
K. Roman
K. Roman's Avatar
I just cleaned my riser tubes and added a little dialectic grease to it. It stopped the failure warning light.
Quick Reply: Spoiler Failure 996TT
