996 Turbo Forum 1999-2005
PSM & ABS failure warning??
Old 09-20-2007, 02:43 AM
turbolou
turbolou's Avatar
Default Reply
I have had the same problem occur under hard WOT blast after I changed out the intercoolers twice this has happened. Before that no problem, Has to be something connected with the installation although I don't know what ? Car runs well & boost is ok. I took it to the dealer since I have an extended warranty. I'm thinking that I just should of bought the software & checked it myself.
Old 09-20-2007, 11:23 PM
MK19
MK19's Avatar
If it's been flashed, it could be related.....it was in my case and Upsolute fixed it free with an updtaed file.
MK19
Old 09-21-2007, 02:14 AM
turbolou
turbolou's Avatar
Default Reply
According to the dealer it was the mass air flow sensor. Hard to believe on a 13000 mile car.I guess I'll just have to wait & see.
Old 09-21-2007, 02:34 AM
Kevin
Kevin's Avatar
Do you have a oiled K&N or BMC? The oiled filter media will knock out the MAF..
Old 09-21-2007, 02:42 AM
turbolou
turbolou's Avatar
Default Reply
Good point, Yes I recently installed a piper cross air filter which did nothing anyway & was told to remove it or the warranty on the new MAF would be voided. I didn't see any change in perf & opted to putting the stock AF back.
Quick Reply: PSM & ABS failure warning??
