Who has Turbo Insignia in rear carpet?
Does this come standard on your TT? How is it attached to carpet? I just order one. It has push-in tags in back but my rear carpet doesn't have any holes to mount it. Just wonder what you have as standard. Thanks.
I don't have the TURBO insignia either and was wondering the same. I have the BOSE subwoofer shelf with ports but no TURBO or mounting holes. It looks like an added part to the rear shelf to cover the subs.
Turbo insignia goes on back carpeted shelf which, if you order the Bose system, is covered up by the subwoofer. If you remove the subwoofer and look behind it, you will see the indentation and the holes for where the emblem should fit. If you get the Bose system, the Turbo script is deleted and the place to install is covered up by the subwoofer.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Insignia:
http://www.carnewal-europe.com/cpx_p96090.htm
Insignia (location) on (rear) carpet:
http://www.carnewal-europe.com/cpx_p96155.htm
Finally, I got around to install it. Drilled three holes and pushed it in.
Pic: http://www.pcars.us/garage.php?mode=view_vehicle&CID=34
The Decal King
Regards
Lefteris
The Decal King
The Decal King
