Ultimate Motorwerks Stage 1 turbochargers and tuning package
#33
Let me preface this comment by saying I do NOT have kevin's tuning...
My car has Kevin's K16/K24 GT1 turbos and it is hard to explain the power these turbos produce. My business partner is not unfamiliar with high HP cars, and today he took "Morticia" for a drive and came back looking green and ready to barf... His exact words were that the acceleration and braking on the car was more abrupt than any amusement park ride one could imagine... This is from a guy who races motorcycles...
Kevin's the MAN!
Mike
Kevin's the MAN!
Mike
#35
Originally Posted by Rickard 993 Turbo
Is any pictures coming..?
Kevin can you list the hp on the kits, flywheel hp please
Stage 1
Stage 2
Stage 3A
Stage 3B
Stage 1
Stage 2
Stage 3A
Stage 3B
The Stage 1 will leave your "stock" X50 car links behind.. It's building boost quicker and more torque/power under the curve. We are also generated more boost than what you are seeing. You would have to mimic what Vincent did to keep up. From my humble experience.. Tuning for tuning, turbo for turbo, a stock K24 (virgin turbochargers) tuned will get walked on a tuned K16 hybrid package that "I" sell. And again, the modes that I do to the housings change the characteristic a the hybrid K16 based turbocharger..
Here is a stg2 and stg3A pump , and a 3A R+D race gas dyno sheets that have been posted for quite some time. Pick your loss factor and you have your flywheel HP...
#37
Yes i know allt that KPG
But this is note what i asked
Im not intressted in US dyno in RWHP and loss factors...
I do not se anywhere the kit listed in Flywheel hp so that why i asked, i also would like to se they listed side by side not diffrent treads that all say diffretn, race gas,US pump fuel, and etc
So your info was nothing new and i have read all your treads hundres time but they dont give me the answears im seeking, i will email Kevin instead
#38
What the hell happened to 3B? I don't know anyone who knows or is willing to tell me what 3B is in detail. What's the deal with stage 4? When is the crate engine option going to be available?
#39
Rickard, I don't have a engine dyno and even if I did I couldn't attach the ECU and full wiring harness to the engine. There is a overlayed dyno sheet the lower output is that of a 550 Ruf package, same engine same dyno, same conditions. SAE corrected factors are used.
Mike, Stage 4 is a Stage 3B on steriods.. Since these guys decided on the case work and the GT3R crank and rods we get to strap on some larger turbo's and we will see where the numbers will settle in.
3B gets rods and extensive headwork..
#40
BUt the reason i ask is this
For example the kit i have from you is the 520-530hp tuning kit,i have exhoust,dv,UMW wg,bmc filter,and the software..this should give me 520-530...Like 80hp more then my car has stock, seams reasnoble for what the stock k24 will flow...
But other like "9eleven" on this forum has over 600hp with less modfication, so when KPG attach a dyno paper it says nothing in my eyes
#41
#42
Mike, Stage 4 is a Stage 3B on steriods...
And are these oral steroids, or do I have to get a sweaty muscular guy to give me a shot in the ***?
These analogies are really useless without hard data
#43
...ike, Stage 4 is a Stage 3B on steriods.. Since these guys decided on the case work and the GT3R crank and rods we get to strap on some larger turbo's and we will see where the numbers will settle in.
#44
Mike, I have a brand new crate engine being built along with the Stage 4's.. All new parts, GT3R crank, late style case, new heads, all new.. Maybe that will be the Stage 5... I can put your name on it..
#45
Here are some pics from the UMW head project. The finished port is on the exhaust side. The unfinished is from the intake and is used to show just how rough the casting is in stock form. There will not be any pics posted of the intake side, but the exhaust side shows the work required to get 300+ cfm flow. The head ports are all port matched to the gaskets as well so there is no excess gasket material that will impede airflow. We are very close. Kevin
