DIY 996TT Connecting Rod Replacement
Carbon from the combustion process.
Alex, no bent rods.. A little preventative measure before dialing it up..
I don't have an "S" shaped rods to show you in this build..
Originally Posted by Zippy
Kevin. What's with the ****e cooked on top of this piston. Is this normal?
Should be fun. Drop me a line sometime! It's 2007 and we need to catch up
It is fricking COLD hear.
I could hear the Lake freezing (cracking every few minutes) last night all night,
our lake has abut 8" of ice on it now.
Marty K.
Marty K.
It's -22' here!
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
With some spare time, here are some pictures with the pistons taken off the rods.
The picture shows the rods and rod bolt/nuts that are to be removed. I use rubber-bands to keep the rods up to prevent case damage.
Once the rod nuts are removed, the upper rod half is pulled out of the case/spigot. I use a magnet to roll the lower rod half/cap. Usually the bearing will stay in the cap.
The bearing journal is exposed. It is in great shape..
![](http://forums.rennlist.com/upload/p1010191_copy1.jpg)
![](http://forums.rennlist.com/upload/rodds.jpeg.jpg)
![](http://forums.rennlist.com/upload/p1010193.jpg)
![](http://forums.rennlist.com/upload/p1010194.jpg)
![](http://forums.rennlist.com/upload/p1010195.jpg)
