Shift Light Installed
Basic Sponsor
Tom,
I like to shift around 6,900 -7,100 RPM's, but I am not certain what is optimum for max acceleration. I have my S100 set at 100 RPM increments with the 1st light at 6,600, so when I see the 1st light - if I shift immediately, I am usually another 3-400 RPMs by the time I actually shift (in 1st gear - other gears are not so quick and you can actually gauge the RPM's by the lights and shift knowing the RPM).
DMaffo was shifting at about 6,000 RPM's on his record setting 10 second 1/4 mile runs. He tried 6,900 RPM speed shifts and could only achieve 11.3's. Then he shifted like you or I (quickly letting off the gas between shifts) and ran 11.4 - 11.5's (not sure of RPM's though). He claims faster acceleration with a short shift and keeping the turbos under load...I plan to experiment with this next season and see how it works. So knowing this, I don't think you are hurting your times if you shift a little lower...at least with the proto package, as that is what he is using. Yes, I set mine a little lower for advance warning in 1st gear, as it goes by so quickly. I like to see the shift completed before the red light, which indicates a shift with no rev limiter interference. The red line is increased with Proto software, unless you specify otherwise.
991.2 GT3 RS Weissach Racing Yellow
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
former 1972 911T white, 1984 911 3.2 Targa black, 993 cab white, 993TT arena red, 993TT silver, 996TT speed yellow, 991.1 GT3 white
www.speedtechexhausts.com
info@speedtechexhausts.com
Testimonials SpeedTech Exhaust Videos facebook
2022 Cayenne White
Basic Sponsor
Dock,
Yes, the shift light takes the RPM from the ECU. The tach needle lags a little behind in 1st gear making the 1-2 shift a guess, but the shift light is right on and shows real time RPM's, which removes the guesswork...
Super Moderator
Needs More Cowbell
Needs More Cowbell
A bit , but I just purchased this shift light for the Cup car (straight version)
http://www.ecliptech.com.au/main_win_sep06.html
(It comes in 2 versions of LED's, GRN GRN GRN GRN YEL YEL RED and BLUE BLUE BLUE BLUE BLUE RED RED....I bought the Blue/Red version)
discussed in this thread:
https://rennlist.com/forums/964-forum/346745-shift-lights-installation.html
Prompt shipping and communication, programmable, nice unit.
Super Moderator
Needs More Cowbell
Needs More Cowbell
All the manuals (install, user guide, etc) are on their website.
BTW, it also measures battery voltage.....it is a very versatile little piece of work.
ltc, could it be you may have an older unit? here's the response I got back from them regarding the on/off switch. I went ahead and ordered the unit, curious as to how it will work out. thank you for the info.
On/Off..Yes there is! There are two buttons on the front of the unit. If theengine is running, just increase the RPM above 2,200rpm and press eitherbutton. That will toggle the display on/off - quite handy. It's theonly thing the buttons allow you to do while the RPM is above thispoint. Alternatively, you can also press the down button to scrollthrough the display modes to get last one, off mode. Cheers,Tonywww.ecliptech.com.au
Super Moderator
Needs More Cowbell
Needs More Cowbell
My apologies, I misunderstood.
I thought you meant an 'on/off' switch like a radar detector, which if left on might drain a battery.
This unit does not have a switch like that, it will simply turn on the display if you choose to. My unit is a little over 3 months old.
