BACK PRESSURE...DO WE NEED IT???
Since I have taken off my 100 cell cats and gone to a straight pipe from the turbo to the tips car seems to stall out easily. dealer says it is most likely the combination of the LWFW and no back pressure.
Well I certainly am not a porsche mechanic but I didnt make the correlation myself.
So I throw myself on the mercy of the court here and hopefully someone knows something about this combination that I dont?
Any insight would be greatly appreciated
tom
tom
light weight flywheel is definatly a contributier....but as for back pressure im gonna say no. With a straigt test pipe on a turbo there is only 12 or so inchs of piping from o2 sensor to tip, on decel and at rest thats not enough pipe to prevent the back flow of fresh air into the pipe and making the car dump fuel to cominsate the lean condtion it is seeing. Ive alwaysheard and lived by the ruel that 18 inchs as the minumum from front o2 senor to end of exhuast pipe on efi cars. Now a talanted tuner could likely adjust the maps to give you a richer idel but then it will smell stinky like my car
The sensors are in approx the same location on the straight pipes as the cats had them. Thanks GTi. firehawk I was hoping you would chime in, thanks. I'm going to ask them about that tomorrow!
thanks again
tom
thanks again
tom
thanks again
tom
thanks again
tom
i understand that but maybe the cats are enough of a restriction (also esentialy a heating element) that the back flow (not back pressure) is negligent. Some thig you could wtach with a scanner and see if the o2s are going very lean on decel and at rest
Tom,
why not run a good exhaust system (of your choice) with cats (high flow 100 cell/in.), and then
you will be able to converse while in your car, use your cell phone, and get your beautiful Turbo
back to proper running condition. I feel your pain. Maybe try new exhaust and new programming?
good luck!
MK
good luck!
MK
Originally Posted by Oak
HELLO! tom, don't you have the EVO LWFW and tuning? If so, this would be the first I have heard of this problem. I know the 993tt has some issues with the LWFW coming off throttle and dieing.
