MAF Cleaning, Parts,and Directions Document
These are the directions for cleaning your MAF. I gathered the directions and parts list from different threads. None of the directions or pictures belong to me. I just gathered them all up and put them in a doc so I could print it out. I figured since I had the document created anyway I would share it. The document has directions, parts list, places to purchase parts, and pictures.
If cleaning the MAF fixed a specific problem for you please reply to the thread and explain what it fixed. This could be helpful for other people troubleshooting MAF related issues.
Thanks to everyone who I gathered these directions from.
Enjoy.
Enjoy.
Well I cleaned my MAF and I do feel a difference. The response feels better and the acceleration is much smoother. My MAF looked pretty clean but since it was off anyway I went ahead and cleaned all the different parts including the connectors. I wasn't expecting to feel any difference at all but did notice the car had a better response and a smoother acceleration.
For $10.00 this was well worth the time and money. I highly recommend it.
FYI...
My car is a 2002 996 Turbo with 22k miles on it and stock airfilter. If you have an after market air filter like K&N it's probably a good idea to clean your MAF anytime you re-charge or replace the air filter or every 5k miles.
FYI...
Cleaned each part with 4 coats. The plug connector I did seperately then let it dry. Then cleaned the other 3 parts. Not really sure what all needs to be cleaned so I cleaned it all. After applying each coat I let it air dry with a micro fiber cloth on the bottom to soak up any extra stuff. I agree with twintime. Better response and much smoother acceleration.
When driving 50MPH and having the car in 5th gear then stepping on the gas the car would sputter a little bit then go. This was fixed with the MAF cleaning.
Could someone please explain why cleaning the car will have any effect on performance...I guess I'm asking what signal does the MAF send (digital) that would change the performance of the car to create the "better response and smoother acceleration". I'm not trying to be an *sshole, I just don't get it. Oh and by the way have you read tthis?:
http://www.knfilters.com/MAF/massair.htm
My questions:
What part of the MAF actually collects data? I saw 3 different parts that looked like they may collected data. If all 3 of them collect data then what happens when 1, 2 or all 3 of them gets dirty? What happens if just half of one of the collectors gets dirty? And last of all what are the symptoms of a bad MAF?
I spoke to a guy at a shop that gave me detailed information of how a MAF works. I wish I could remember everything he told me. But basically the wires on the MAF heat up and cool down from the air passing by the wires. The way the wires cool down and heat up controls how the air / fuel ratio's should be mapped. Something like that anyway. If anybody can explain this better please feel free.
Originally Posted by shane.emc
I spoke to Bill at the German Car Garage in Mission Viejo, Ca. and he gave me detailed information of how the MAF works. I wish I could remember everything he told me. But basically the wires on the MAF heat up and cool down from the air passing by the wires. The way the wires cool down and heat up controls how the air / fuel ratio's should be mapped. Something like that anyway. If anybody can explain this better please feel free.
"One side of the film encounters cooling airflow, while the shielded backside maintains a consistent temperature, and the current differential between the two is measured and relayed as a square-wave digital frequency output, between around 30Hz at idle and 150Hz at wide-open throttle. Hot film sensors tend to be more robust and less susceptible to contamination than hot-wire types."
Originally Posted by JasonAndreas
You want to spray #2
in the direction of the arrows.
Internally your 996TT MAF looks like
Technical Guru
Originally Posted by Gary (Fl)
could that be my old blown MAF ???
