First Stages made HUGE Horsepower Gains
Former Vendor
Stage 1 - Project 996TT Goes Under The Knife
CLICK HERE FOR PICTURE GALLERY
The first step in the Project 996TT was to get a baseline. Vivid Racing uses an All Wheel Drive Mustang Dyno at its executive facility in Arizona. With the room cooled down and the fans moving, our 996TT baselined at 323 wheel horsepower with 333 ft/lbs of torque. 2 factors here, hot temperature, AWD dyno, and the Mustang Dyno reads a bit lower then others. Generally you have about a 20% drivetrain loss with AWD cars, so we are pretty close. Once the baseline was complete, it was time to MOD.
Our first order of business was to do an ECU Reflash to really open the cars capability. Upsolute (www.upsolute.com) is the newest in ECU reflashing. Vivid Racing, an authorized tuning center, simply plugs into your ECU and changes the map to a safe, but more aggressive map. Changing your boost to 1.0 bar and altering your fuel and timing maps to gain more HP and Torque. Upsolute claims about 90hp gain and almost 100ftlbs of torque increase. We put the ECU Reflash to the test, and for a $700 retail price, why not. That is $1300 cheaper then the competition... After our ECU Flash was completed, we strapped the car back on the dyno, fired up the fans, and gave it hell. For $700, Vivid Racing got 412 ft/lbs of torque and 417 wheel horsepower. And that is ALL WHEEL HORSEPOWER!
CLICK HERE FOR DYNO SHEET 1
Next, we could see that our boost was not staying consistent because the factory diverter valves were most likely bleeding off boost. So we called up our good friends at Forge Motorsports (www.forgemotorsport.com) and got a set of the original billet diverter valves with performance spring kit. These valves were available in black or polished to us, and to bling, we took the polished. When we went to remove the factory ones out, we found that there was already some kind of aftermarket diverter valve in it. We removed the black valves that were leaking and sticking and put our new Forge valves with upgraded stiffer spring for up to 23psi of boost. Since our boost was more consistent, we made 428 ft/lbs of torque and 412 wheel horsepower. The power curve was increased down load and through the midrange. Not bad for being only $280 for the pair.
CLICK HERE FOR DYNO SHEET 2
Our last mod and most controversial one is the Fabspeed Intake Kit (www.fabspeed.com). Fabspeed intake kit is brand new on the market. Utilizing a flat panel BMC filter like the factory one, they retain the factory air box and use an aluminum plate and heat shield. The open air intake receives air from the factory air inlet and the engine fan. The filter is cleanable for the life of the filter and is out of the way from water and other major elements that could harm your engine. Before we dynoed the Fabspeed kit, we did just put the BMC in the factory air box. Our OEM filter was brand new so the difference was only about 5 wheel horsepower. Once the Fabspeed intake kit was installed, we fired it up on the dyno and made 3 pulls. The Fabspeed Intake kit definitely flowed more air flow then the stock one. The Mid to High RPM power was increased, where some low end was sacrificed, but that is normal for almost ANY intake for ANY car. The Fabspeed intake kit made 421 ft/lbs of torque and 423 wheel horsepower. Bottom line is it made for us in our conditions about 20 PEAK HP and Torque at 5500rpm's. Again for $546, not a bad upgrade.
CLICK HERE FOR DYNO SHEET 3
All and all, the Stage 1 kit we did of the Upsolute ECU Reflash, Forge Diverter Valves, and Fabspeed Cold Air Intake, netted our Porsche 996TT about 90 ft/lbs of torque and 100 wheel horsepower gain. At a retail price of about $1500, that is over 50% cheaper in price for more WHEEL horsepower and torque. Are we stoked? Very! Next step, Fabspeed Exhaust and Headers. Stay Tuned!!!
If you have any questions on the aftermarket parts explained in this article, the package or individual pricing, or how the tests were done, please contact our TUNING department to get hooked up at tuning@vividracing.com or call 1-480-966-3040 x236.
CLICK HERE TO BUY STAGE 1
Former Vendor
You would probably lose some torque and gain another 10 HP on the top end. Peak HP would probably be greater then 20. I got those available. Let me know if you want a deal. Pic looks good!!!
I am very suprized by the HP gains of the flash, it seems way to good to be true. Did you drive the car with just the flash to test driveability? You mentiond that boost wouldn't stay constant, was this a "dyno issue" truing to maximize HP, or also one that would effect driveability?
Does anyone else have experience with this ECU flash?
