Do all 996tt have PSM? And do they all the option of switching it off?
Originally Posted by stuka
It is much much worse than that. In the dry, with PSM off, as you begin your turn in, stomp on the throttle, and PSM, even with that nice big amber light telling you that it is off, will still NOT, will NOT, allow the back end to come out.
I have a little bit of experience with my Turbo on dry, wet, snowy and icy roads. With PSM off, it's pretty easy to have the rear come out.
Ok, these pics are not exactly on the dry, but the same kind of behaviour happens on the dry too. Is something wrong with your car?... Weird...
--p
My understanding is that PSM only kicks back in when the brakes are applied.
Stephen
I have been doing DE for a while, and I don't understand why anyone who has progressed out of the slow group need PSM on. For crying out loud, it turns itself back on even when it detects power on oversteer. See my above post for example.
I like my Turbo, but it really does look like I need to get a GT2 (which I have been looking) to free myself from this stupid nanny that just won't go away. Heck, my previous hamster powered E46 M3 lets me shut off DSC and it stays off.
When you throw the car into the turns and somp on the throttle with the PSM what does it happen? Does the car kill the power or the car understeers? If its the 1st all you need is to make a few changes to remove the cars artificial tendency to understeer (doing suspension, rear GT2 bar, wheel alignment and 235 tyres) this way the csr will show a neutral handling and when you stomp on the throttle oversteer will be present at your will. If the PSM still cuts power under acceleration mans its not desactivated.
Originally Posted by Dock
I agree. With PSM off, I have no problem at all hanging the tail out.
When you begin your turn in, you keep the steering bound up (do not unwind), you leave it in 1st, you stomp on the throttle.
The rear end drifts out a little, and then it stops drifting because PSM, now with that big amber light staring at me from the dash, decided that the car is sliding and it must correct itself, kills the power.
Now, in a normal rear biased or RWD car, the car will keep sliding until a steering correction is made. This is NOT the case with PSM, on or off, doesn't matter. What I want is when I do the above, the rear will continue to come out, as I leave my foot planted on the floor, and correct the car myself.
This is not allowed under PSM. On or off.
Originally Posted by GreggT
Stuka...........congrats on making it out of the slow group. And, if I may, reading this may help you understand your PSM a bit better Jack Miller on PSM
I have read that article, and PSM still sucks. My point still stand that PAG should have made PSM totally defeatable, like any 30K BMW.
That is not the case here.
PSM will allow you to get the tail out a little, but it WILL NOT, at least on my car, allow the slide to continue. As inm if you keep your foot planted in 1st and second while keeping the steering bound up and do not unwind, PSM will turn itself back on and kill power, stopping the slide.
A normal rear biased AWD cars or RWD cars will continue to slide until the driver does something to correct the slide. That is what I want, and what I am not getting.
OK, maybe I am not making myself clear.
With the PSM selected off, there is no system intervention *at all* until the driver engages the brakes.
If you are experiencing PSM intervention with the system selected "off" in the cockpit, and without any brake application, then your car is malfunctioning.
With the PSM on, the system will allow about 7 degrees of side slip before interviewing.
1. 1st gear, turn in, keeping the steering bound up and do not unwind.
2. PSM shows that it is off.
3. I stomp on the throttle.
4. The car drifts a tiny bit, then the PSM light flickers, and the car stops sliding.
So this is the car malfunctioning? Boy, am I going to have fun trying to have the service guy replicate this along with my clutch problems.
Have you tried in 2nd gear and rolling? I did some donuts once in first gear but it was wet probably its a 1st gear protection thing, try sliding the car in 2 nd on a wide area... if it kills the power with the PSM off (remember PSM is with the red buttons light lit) then the car is malfunctioning.
