996 Turbo Forum 1999-2005
Greetings from the 964 section.....wheel info please :-)
Old 12-17-2005 | 05:11 PM
ttAmerica RoadsterAWD's Avatar
Default Greetings from the 964 section.....wheel info please :-)
Howdie guys. Lurking from the 993/964 to see if anyone can give me some info on your stock wheel/tire size. I'd like to know what is the back spacing on the rear 295/30/18's. I'm cornfused about ET, and find it easier to measure back spacing to see If I can fit the rear's on my Turbo 964 Cab. Also, what's back spacing for the front?
thanks a million.
Jaime
Old 12-18-2005 | 12:30 AM
gr8330's Avatar
gr8330
Try these
http://www.wheelexperts.com/index2.html
http://www.wheelenhancement.com/
Call and talk to them they are very knowledgeable
Old 12-18-2005 | 02:52 AM
ebaker's Avatar
ebaker
7.25" from the hub centerline to the inner tire mounting surface. Add about 1/2" for the width of the inner rim lip. It will be about 7.6" from the inner tire sidewall to the hub centerline with 295's, 8'' with 315's.
Old 12-19-2005 | 03:14 AM
thanks ebaker! the "hub centerline" same as the hub mounting surface.....right? Also, is this for the rear only or both front and rear??
Jaime
Old 12-19-2005 | 03:40 AM
ebaker's Avatar
ebaker
Yes. Also these dimensions are for 996TT 18x11 rear wheel.
Old 12-19-2005 | 01:52 PM
Thank you Sir!
Jaime
Quick Reply: Greetings from the 964 section.....wheel info please :-)
