Speedometer 996 turbo
I have a 2001 911 TURBO and i think at one time i could change the MPH with the onboard computer so that it could be seen at the bottom of the Tach. Am i right of wrong? I called Porsche today and they told me that it was not suppose to change to the Tach. It will change to MPH on the Tach but the MPH is way off from the Speed shown on the speedometer. I am talking about the bottom of Tach where you can show Temp Bar and ect.
Thanks For any advice on this.
RLM 060615-6193
RLM 060615-6193
Yes, you should be able to change to veiw this readout at the bottom area (small screen below the tach). I have mine to show temp on the top and bar on the bottom. I can also scroll through the rest if I am interested in mpg, how many miles I have left, average speed.... I think it's under set and then display.
Mine is only 2 mph different.
Which is more accurate, analog or digital?
Maybe mine is set on average speed ...i will try it again...........i have already disconnected the battery cable and let the computer reset and it did not help.
I don't think actual road speed can be selected in the tach.
This is a flaw as the analog speedo is next to useless and the digital reading in the speedo would be easier to read if it were bigger and in the line of sight in the tach.
Originally Posted by whiteturbo
Thank You Jools. I see you are in NC i am in NC also.........about 40 Miles west of Charlotte.Shelby NC.
