996 Turbo Forum 1999-2005
CA smog II?
Old 09-11-2005 | 09:01 PM
Tom M'Guinn's Avatar
Tom M'Guinn
Default CA smog II?
Do 996tt cars have to run on a dyno in smog II areas? If not, do you just get the visual and idle tests?
Old 09-11-2005 | 10:10 PM
calcareer's Avatar
calcareer
There are no Smog dyno's that can accept AWD. Therefore, all that must be done is a visual and idle test . The GT2 can run on the Smog dyno though.
Old 09-12-2005 | 12:12 AM
Tom M'Guinn
Interesting. So I guess smog checks are not much of an issue on anything but the most highly modified car... particulalry in light of the limited view of the motor.
Old 09-12-2005 | 01:29 AM
calcareer's Avatar
calcareer
As long as the cats are in place as well as the other smog equipment to pass a visual, there should be no problem even with high horsepower modifications.
Quick Reply: CA smog II?
