spanner wrench????
spanner wrench????
my new carbon wing should be here mon, have allens but the spanner wrench??? how does this come into play?is the wing removed by removeing the allens under the deck lid or is that little hole on the inward side of the post a keyway to remiveing the wing help steve
When you raise the top wing, you will see a "hole" in each shaft. Using the spanner wrench, you will rotate the hole ~90 degrees (essentially lines it up with the interior slot). This will allow the wing to be removed from the shafts. After you remove the wing you will need to remove the insert inside the wing with the allen wrench. Put on the loctite and then re-install.
