996 Turbo Sticking Sunroof
4th Gear
I have a 2003 996 Turbo Coupe. The sun-roof, slides back to open OK but on closing often sticks and needs to be manually pushed in order to close. I think the top of the sun-roof is actually catching, or rubbing inside somewhere. It's not covered under warranty, dealer reckons it needs re-aligning, or adjusting. I reckon I could do this myself, but dont know where to start. Can anyone assist? Ive done a search but can't find anything on 996 sun-roofs.
LPFR - not sure if the symptoms are the same but I have recently experienced problems with the sunroof closing on my '03 as well. It opened ok but would usually not close completely when the button was depressed. It would start to close but would stop at half-way and immediately reopen as if it had hit something; this happened about 80% of the time. My dealer acknowledged that several other of their customers have had this same issue and replaced the motor. This was 1 month ago and I haven't had any problems since.
Do you hear or feel any vibration when the sunroof comes to a stop?
kristap
kristap
4th Gear
Kristap, Thanks for post.
Yes, it does make a noise as the roof stops, as if the motor is speeding up before it expires. I have now got car booked into a dealer for diagnosis,next week, on the understanding that this will be a warranty job.
Had similar problems with the sunroof. Had to push it closed manually. Turned out to be the motor failed due to lack of track and cable lubrication. Not much we can do about it because the parts that need lubed are not accessible. Replaced motor under warranty.
