Ceramic Brake "Loud Noise"
I was driving one saturday on the freeway & side street and the temparture was in the mid to hi 80's. Normal driving conditions. And all of a sudden when
i hit the brakes i heard a loud humming sound! not a squeel! Has anyone out
there experince something like this on PCCB's? I have a 05 Turbo S only with 1500 miles on it. I have pampered this car since i drove it off the dealership.
It's disappointing to hear a superior brakes to fail if so? on
a 150K price tag automobile.
Any comment or adivce will sure be appreciated. I plan to take it to
the dealership.
_________________________
2005 Turbo S
the dealership.
2005 Turbo S
The PCCB's often make strange sounds. Not indicative of a problem. A few have mentioned a grinding type of sound. It maybe harmonic issue due to pads and disk seating during break-in.
FWIU, the 05 turbos have the 2nd generation PCCB which seem to not have all the controversy and problems of the 1st gen.
the dealership.
2005 Turbo S
the dealership.
2005 Turbo S
However, if you have not already then do a proper "bedding-in" of the pads and rotors. This is important. Do a search on this forum and you'll find a detailed procedure on bedding-in. Good luck!
To Gary Cooper, it seems to be the brakes, it only made that loud noise when i hit
the brakes. It seems to sound like metal to metal contact when your pads are worn!
Stephen
I just changed the pads in my 03 X50 with Gen 1 PCCB's - I got 66k miles and 6 DE events on the original set - they like a progressive warming on the track (3 laps or so) and then hammer them - I just took it easy for one day on the new pads and then performed a series of progressive brakes as descirbed above and they new pads feel great. I have had instances where a pebble will get caught in them somewhere and squeal like hell for a second then fall out - maybe your ABS or PSM kicked in prematurely for some reason - just two thoughts. Good luck with them.
