Cargraphic EXPORT Exhaust
I have the cargraphic. i don't know how many models they make, but mine is the quiet version. The reasonance is very low you can talk and listen the radio if you'd like. At full acceleration, the exhaust sounds deep and rich. I had the fabspeed, too loud at 2K-2.5Krpms.
the cargraphic export is on the loud side esp at cold start up and with moderate resonance. another issue is if your suspension is lowered the exhaust cannisters have a tendency to bottom out and scrape over speed bumps. the build quality isn't as top-notch as ruf of euro.
The CG is a very quality exhaust that produces real gains. The resonance is little to none and the cost is better than the likes of RUF which is a modified factory muffler not proven to make gains. We have sold the quiet to loud and they are all a great sounding exhaust for the money. Ask Jim. He was concerned about the noise. I made a promise to him that I knew I could keep!
strange I had the cargraphic orginally and had the opposite results. the ruf made much more noticeable torque esp through through the mid range. the cargraphic has much more drone resonance than the ruf. the ruf is almost near stock when idle and normal driving but when at full throttle has a much different pitch. shades of F1! will post sound clip if I can find the one Jack had.
Not sure how long ago you bought yours but we started selling them in the last year or so and they have been pretty good with no issues.
Sorry, all the dynos we have ever run on the RUF have lost power across the board. I will post or fax dyno sheets if you request. The RUF is a factory modified muffler so I hope the build quality is good. Then again many have complained that the packing burned out over time and have sold the exhaust as many have with other brands due to noise.
stephan, I remember seeing those, Richard maybe interested in seeing. My results have been the opposite. Not sure about the new ones but it seems like the construction was not that great, esp the wields. Construction wise they are in a different league.
I would put one on my car if that says anything.
Those are not the only dynos I have. They carry a large amount of back pressure compared to the others on the market and are restrictive. Like I said the hard data has proven different If you have hard data that shows other you should certainly post it.
Most of the exhaust out there make some gains. There are only a handful that net zero or a loss.
If you wouldn't put one on that means some thing! I guess Ruf shouldn't either, how ever I wonder why if his exhaust lost power why he continues to use this design? Ruf engineering is top-notch and he doesn't seem to comprimise in design and performance. I'm sure if he has had the same results he would not continue with his design.
Anyways, Richards question was orginally about resonance. You have to atleast agree the Ruf has less resonance.
Sorry, I guess Jack has moved on. I can't seem to find his excellent sound clips of the Ruf.
I know not all of their systems use that muffler. So while it may work with some it was not something I would use or sell. The back pressure was too high and shows great restrictions. This was shown in the chart when the system would get hot the air would thin enough to move through. I had some talks with the engineers that called after the testing. They too agreed that something was wrong. I never heard back from them as promised so assume that nothing has changed. Keep in mind that it is not their design. It is a modified factory muffler. We make them here in house as well. If you can tig the quality will be as high since little is done from the outside.
Yes, less resonance for sure. But you have to be careful explaining what is less. Jim is sensitive to the resonance and agrees that the CG has little to none. Others think the FS moderated is quiet and so on. The problem with talking about noise is it subjective. I believe that Richard would like the CG and it proves to be quiet and deliverer gains for apx 1800.00 less than the Ruf piece.
Like I said, it is subjective. Some think Europipe is too loud, RUF is too loud. Personally If I can hear the blower on the low speed at 2500 RPM and I can carry in a conversion in the car and my boys can still take a nap and talk to me it is good!
991.2 GT3 RS Weissach Racing Yellow
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
former 1972 911T white, 1984 911 3.2 Targa black, 993 cab white, 993TT arena red, 993TT silver, 996TT speed yellow, 991.1 GT3 white
www.speedtechexhausts.com
info@speedtechexhausts.com
Testimonials SpeedTech Exhaust Videos facebook
2022 Cayenne White
