996 Turbo Forum 1999-2005
Oil Burner
Old 08-06-2004, 04:22 PM
Iloveheat
Iloveheat's Avatar
That's exactly what I did. YOu have to pull its nec a couple of times per day, and run the engine anyway at 4000 or a bit over it always. That is what I did.
Paul
Old 08-06-2004, 07:45 PM
1AS
1AS's Avatar
MMH,
There was a thread long ago on break-in procedure which described hard acceleration and in-gear decelleration in a defined sequence. You might want to pull that up to see if you want to modify your driving style for a while. AS
Old 08-06-2004, 07:48 PM
BrianPA
BrianPA's Avatar
Are turbos supposed to consume more oil than non turbos? My GT3 never consumed anything during breakin or after...
Old 08-08-2004, 09:40 AM
SimonK
SimonK's Avatar
Hi, just passing through your lounge on the Sunday. If a turbo car is driven hard it will consume more oil. Simple as that. The piston rings are designed to bend at high load to increase lubrication. Porsche does this on purpose. Also the hotter the turbo it will force the oil past the turbo (s) seal. Even for my low tech 944 turbo S - 1.5L of oil per 1000km or 620 miles is normal. If you take your cars up to 100mph you will not use up any oil. Beyond that better carry a spare 1L can of oil on long fast trips....
Old 08-08-2004, 12:09 PM
Meeyatch1
Meeyatch1's Avatar
Location: Fishers, Indiana (USA) and Barrie, Ontario (Canada)
Originally Posted by dpj
Just got my 01 996 tt a 30000 mile service. It is burning a quart of oil every 600 miles. Porsche claims it is normal because I drive the car hard. I don't....is this normal???? Please advise.
I would push for more testing, and tell them you really do not appreciate the implication that you beat on your car like they are saying (assuming that is true).
Old 08-14-2004, 02:19 PM
MMH
MMH's Avatar
It's MMH - sorry for the late follow-up. I followed instructions and didn't push it too much for the first 1k miles... I'm bringing it into the dealer since I noticed about 1/4 of a quart below my car when pulling into the garage last weekend... not good. Also having some spoiler failures. So we'll see...
Old 08-16-2004, 10:30 PM
mmcmilla
mmcmilla's Avatar
I have 750 miles on my new 2004 turbo. I'm generally observing the break-in rules (RPMs under 4200 for first 1800 miles), but I'm varying RPMs quite a bit and occasionally going over 4200 (but not redline). My salesman said he checked with the Porsche service manager at the dealership who said, "don't worry about any break-in." But I always liked the guy on a previous thread who said, who ya going to believe, your saleman or the engineers at Porsche who wrote the section in the manual about break-in?
I don't think I've burned any noticeable amount of oil yet. Still reads between the min/max marker.
Old 08-17-2004, 01:52 AM
Zen dude
Zen dude's Avatar
I have read that you have to break in a engine on regular oil so it will seat the rings, takes 3000 to 5000 miles, then you can run synthetic oil. If you have always ran synthetic oil than switch to regular oil for two oil changes, then go back should seat the rings. Good luck.
Old 08-17-2004, 12:59 PM
Iloveheat
Iloveheat's Avatar
My dealer doesn't replace the oil until the 15000 miles! Someone in a performance shop told me that syntetic is BS, in F1 and other racing category only regular oil is used. But 15000 miles without changing oil?!!!
Paul
Quick Reply: Oil Burner
