Digital vs. Analog Speed Reading
I noticed the other day that the Digital speed indicator was 10mph higher than the Analog dial. I know the car is not a plane and the difference is not the air speed vs ground speed. I pulled into a Gas station filled up with gas and was on my way. After I left the gas station everything was fine. So, I thought the problem had something to do with the amount of gas in the tank...
Well, the issue happened again a day later. Once I stop/start the car the problems goes away.
Any suggestions?
Any suggestions?
No changing of tires or wheels. 90% + of the time digital & analog are identical. However, I noticed two times the 10mph difference, and after restarting car the difference went back to zero.... I don't know how to reproduce this issue, so I guess it will be difficult for the dealer to reproduce.
