996 Turbo Forum 1999-2005
View Poll Results: Choose Your Size
Front 225/40/19 Rear 295/30/19
14.29%
Front 245/35/19 Rear 305/30/19
85.71%
Voters: 7. You may not vote on this poll
Tire size for 19's
Old 09-18-2024 | 01:22 PM
Coñoooo 911's Avatar
Coñoooo 911
Default Tire size for 19's
Recently I had a set of wheels made through VT Forged 19x8.5/11
I've read a bunch of post about this, sooo "sorry in advance lol" I'm currently between two tire size sets.
and
The car currently has Techart Coilovers and adjustable toe arms. I'm just trying to see what everyone here would go with?
Old 09-18-2024 | 01:43 PM
Capt. Obvious's Avatar
Capt. Obvious
I like the wheels, they should look great on the car.
I run a 245/305 combo on my car for a few reasons
- More tire is better
- The taller tires are a better match for the gear ratios (in my opinion)
- Tire availability
- It looks better aesthetically because the fender wells on a 996 are large
Old 09-18-2024 | 01:57 PM
Bernard IV's Avatar
Bernard IV
After installing the 245 front I'm pretty sure the 225 is to tall.
Old 09-18-2024 | 02:00 PM
kflee's Avatar
kflee
Beautiful wheels! I am also running 245/35/19 and 305/30/19. However, I think you would need to be RWD as the front diameter is smaller than the rear by almost a 1/2".
Kirk
Old 09-19-2024 | 11:38 AM
Bernard IV's Avatar
Bernard IV
For those wheels I'd go with
245/35/19 Fronts (25.8 diameter)
295/30/19 Rear (26 diameter)
That's the closest you can really get and still have some good sidewall. The fronts may rub a bit at full lock in the parking lot but this hasn't been an issue for me.
Here is a tire selection thread I made a while back: https://rennlist.com/forums/996-turb...996-turbo.html
Old 09-19-2024 | 02:52 PM
2fcknfst's Avatar
2fcknfst
I run 245/305, but I've pulled my front diff.
Good looking wheel.
Old 09-19-2024 | 03:33 PM
Bernard IV's Avatar
Bernard IV
That has been a good combo even with a front diff in place it seems to be working fine and puts a ton of rubber on the road. The 245 front really cures the understeer. If you have a 12 inch rim you can't use the 295 rear and must go to the 305.
Old 09-19-2024 | 03:36 PM
2fcknfst's Avatar
2fcknfst
Yep, 12s on the rear.
Old 09-20-2024 | 05:24 PM
Coñoooo 911
245-305 it is. Thanks guys!
Old 09-20-2024 | 05:35 PM
2fcknfst's Avatar
2fcknfst
Welcome.
Old 09-21-2024 | 02:32 PM
Coñoooo 911
Kirk
should I run a 12mm wheel spacer on the front?
Old 09-22-2024 | 08:28 PM
theprf's Avatar
theprf
I run a 305/30 19" rear which works ok on my moderately lowered car. On my slammed car it rubs the rear fenders despite rollling them.
Old 09-23-2024 | 10:20 AM
kflee's Avatar
kflee
A spacer will not correct for a diameter issue. A spacer is used to push the wheel/tire out to correct for a wheel that has an offset that is too small. Do you know the offset of front wheels? Rear wheels? If they were made for the 996 widebody, then I am sure they are good, so no spacer needed.
Kirk
Old 09-23-2024 | 11:07 AM
Bernard IV's Avatar
Bernard IV
That may be an issue with your offset. My 315/25/19 setup fits fine in the outer fender but is a bit close against the inner liner, I had to melt it and push it in a bit.
Old 09-23-2024 | 09:24 PM
theprf's Avatar
theprf
Quite likely. These rims are old, out of production from a Swiss tuner, probably 15+ years old. There are no markings on them at all.
They sure look good though.
Quick Reply: Tire size for 19's
