Front Wheel Wobble - Can't Find The Cause!
#31
He'd only feel that under braking, and it would be at all speeds.
Jedi767 (08-22-2024)
#33
#34
From what I understand and I maybe wrong, rotors are balanced during manufacturing just like wheels/tires so it might be a fluke but maybe he has a front rotor that somehow went out of balance.
My money though is still on the steering rack.
#35
Bent hub/mis pressed into bearing will cause a shake. Inner tie rods?
Are you running spacers? These are always suspect, I have found multiple brands of them that were up to .015" out of parallel from front to back surface with Rennline ones being the worst offenders.
#36
It's a bent front wheel hub.
Pull off the wheel, caliper, and rotor. Inspect hub surface where the rotor sits for corrosion. Corrosion adds thickness in unpredictable places which causes the rotor/wheel stack to be mounted slightly askew.
If no corrision measure runout on the rotor mounting surface of the hub. It ought to be zero but a few thou is probably ok.
Check both sides.
Check both sides.
#37
#38
Check both sides.
Check both sides.
#39
We should start a pool on this thread...
The following 2 users liked this post by 2fcknfst:
Jedi767 (Yesterday),
TheDeckMan (Yesterday)
#40
#41
One of my rear twists has a slight bend in it, we cannot seem to balance it out, after straightening the wheel.
This, of course, shows as a slight vibration at 65/70mph, nominal cruising speed for the highway, so it is super irritating.
#42
I am willing to bet OPs problem has to do with one of his rear axles being bad or out of wack. Ive heard of cars having issues like this and it was the axle, despite the fact that the boot wasnt ripped. I know he said its coming from the steering wheel but perhaps he could try looking there.
#44
