996 Turbo Forum 1999-2005
Random Technical Info BS Thread
Old 03-14-2024, 06:54 PM
vtec_
vtec_'s Avatar
Default Random Technical Info BS Thread
I derailed the Xona Rotor XR1000 thread with my newbie questions...
I can't be the only one who has random questions but doesn't want to start a new thread for everything that pops into my head..
Ask anything regarding maintenance, turbos, suspension, modifications, tuning,etc
G8rJimbo (03-15-2024)
Old 03-15-2024, 09:59 AM
vtec_
vtec_'s Avatar
My TT is a 2003. It has green coolant in it but I know it's supposed to come with the pink stuff.
Is the green coolant eating away at my water pump seals? I am replacing one of the radiators soon and will be using the proper coolant.
Old 03-15-2024, 10:25 AM
Carlo_Carrera
Carlo_Carrera's Avatar
Received 2,531 Likes on 1,600 Posts
Green Ethylene glycol coolant will not eat away at your water pump seals. But you should do your best to completely flush the system when your replace it with the pink OAT stuff.
vtec_ (03-15-2024)
Old 03-15-2024, 11:41 AM
vtec_
vtec_'s Avatar
Thanks! VW G12/40 or can I get away with Zerex G40? I've seen people reference it but not sure if anyone here has used it.
Old 03-15-2024, 11:45 AM
Bernard IV
Bernard IV's Avatar
You can use the latest Zerex stuff is totally fine. It pretty much all comes from a handful of factories. You're gonna have to probably fill with water first to flush as much as possible.
vtec_ (03-15-2024)
Old 03-15-2024, 03:16 PM
Capt. Obvious
Capt. Obvious's Avatar
Received 1,500 Likes on 826 Posts
You can safely use either green or pink/purple coolant in these cars as long as you don't mix them.
Old 03-15-2024, 03:58 PM
Carlo_Carrera
You can any color OAT coolant you want, as other have said it is best not to mix them.
Old 03-15-2024, 04:24 PM
T10Chris
T10Chris's Avatar
What oil is best
The following 3 users liked this post by T10Chris:
LinwoodM (03-15-2024), rituxumab (08-19-2024), Sajan (03-23-2024)
Old 03-15-2024, 04:47 PM
2fcknfst
2fcknfst's Avatar
Received 4,137 Likes on 3,130 Posts
The Audi pink stuff is identical to the Porsche stuff, way cheaper.
kamlung (03-28-2024)
2fcknfst
2fcknfst's Avatar
Originally Posted by T10Chris
What oil is best
That's a thread all by itself...
Old 03-15-2024, 04:50 PM
Capt. Obvious
That's a site all by itself.
...and they don't have a definitive answer.
The following 3 users liked this post by Capt. Obvious:
Carlo_Carrera (03-15-2024), rituxumab (08-04-2024), Sajan (03-23-2024)
Old 03-15-2024, 04:58 PM
QwikKotaTX
QwikKotaTX's Avatar
My favorite are the guys on BITOG that re-use $8 Fram Ultra filters THREE times to prove how awesome they are. The new synthetic media and silicone anti-drain back valve are great but WTF is the point of re-using a cheap filter? It's the weirdest bragging right I've ever seen. I use them in my Ram but only once, hah.
Sajan (03-23-2024)
Old 03-15-2024, 06:08 PM
2fcknfst
2fcknfst's Avatar
I'm just about to do the 2500 mile oil change for breaking in the new motor on the Soobie - I have no idea what oil I should use.
Old 03-15-2024, 06:10 PM
Capt. Obvious
Apparently Pennzoil is very well regarded nowadays?
Personally, I use Rotella T6 in everything I own that uses a 5-40. I guess they also have a 5-30 T6 now.
Old 03-15-2024, 06:12 PM
2fcknfst
2fcknfst's Avatar
I have always been partial to Mobil products for gas engines; I use Rotella on the diesels. Maybe I'll try that - it'll be a short change anyways, only another 2500 miles, it'll be interesting to see if the oil consumption drops.
Quick Reply: Random Technical Info BS Thread
