996 Turbo Forum 1999-2005
GT3 Billet cover question
Old 10-27-2023 | 12:34 AM
mrdstr's Avatar
mrdstr
Default GT3 Billet cover question
For any of you running the CMS GT3 billet side cover on your gearbox, what did you do with the coolant hose holder from the old cover? Not seeing a way to mount it to the new one. What do I need to do to keep the hoses off the CV and axle shaft? This is not my photo, but gives a great shot of the bracket and hoses
in question.
Old 10-27-2023 | 05:34 PM
powdrhound's Avatar
powdrhound
I honestly think those covers are a waste of money. We've always run the OEM cover for years of track abuse at +800whp with zero problems. I assume you could improvise and drill and tap an attachment point for the bracket on the CMS cover. Should be easy...
Old 10-27-2023 | 08:19 PM
mrdstr's Avatar
mrdstr
it would be easy if I knew about it when it was out of the car. C'est la vie. I'll figure something out.
Old 10-28-2023 | 12:18 AM
Asmig's Avatar
Asmig
There is a different bracket for the GT3 trans that holds the lines from above. Part number is 996-106-526-90
Old 10-28-2023 | 08:37 PM
mrdstr's Avatar
mrdstr
Where does it attach to? I don't see a point above that general area where this would go. Do you have a photo of one installed? The parts diagram doesn't really show where on the vehicle it goes.
Old 10-28-2023 | 08:45 PM
993GT's Avatar
993GT
agree, think it's safer still with a beefy diff like the Guard
top of the trans, really could just make your own.... here's a 7gt3 trans I have out right now:
Old 10-28-2023 | 08:54 PM
mrdstr's Avatar
mrdstr
Awesome! That I can do. thanks for the photo.
Old 10-28-2023 | 08:55 PM
993GT's Avatar
993GT
no problem! I can grab some better pics if you need...can also hold the hoses factory style with 99951302340 special zipties
Old 10-28-2023 | 11:14 PM
powdrhound's Avatar
powdrhound
It's the hole that you see the hose clamp for the -8AN fuel line bolted to on my gearbox. I am not sure if a 996TT gearbox has this or just the GT2/3 gearboxes. I would suspect they are all pre-tapped however.
Old 10-29-2023 | 04:56 PM
mrdstr's Avatar
mrdstr
It was tapped. I was able to fab something for the time being. Thanks for everyone's help. I think I will likely go with the GT3 bracket if the homemade solution presents issues.
Old 10-29-2023 | 11:06 PM
993GT's Avatar
993GT
99610652690 is the # for the GT2 / GT3 support
Old 10-30-2023 | 01:55 PM
powdrhound's Avatar
powdrhound
If anyone needs them, I have all the GT2/3 heater hoses, pipes, and the above bracket. They are all virtually new as they were replaced a few years ago. I removed these from my car when we removed the heater core system.
Quick Reply: GT3 Billet cover question
