996 Turbo Forum 1999-2005
No A/C and lots of foam from vents
Old 09-02-2023, 06:26 PM
RennKit-Dave
Basic Sponsor
RennKit-Dave's Avatar
Default No A/C and lots of foam from vents
My track car. AC working great until last session here at Road America. Then no AC (yes I use it to stay cool on false grid) and starting to see lots of foam from vents. Could the two be related? What shall I check to diagnose AC system?
Dave
Rennkit
djcooper@rennkit.com
http://rennkit.com/
  • Patented eRam Kit™ for 996/997 Turbo & Carrera GT wings
  • Cal*Cool™ - brake cooling 996/997 / Bluetooth Retrofit Kit™ for 1998-2011 cars / Wing Extenders™ 987 Cayman / 997 Turbo
  • AUTO-BLiP for MT / Function F1RST Shift ***** / Girodisc 2-piece rotors / OS Giken LSD / Phenix suspension / Zunsport grills / 997/987 switches/PCM ***** / Border Coilovers
Old 09-02-2023, 06:45 PM
Carlo_Carrera
Carlo_Carrera's Avatar
Received 2,482 Likes on 1,567 Posts
I think you have the infamous blend door problem in your HVAC system. Check out this link.
https://rennlist.com/forums/996-foru...-issue-14.html
RennKit-Dave (09-02-2023)
Old 09-02-2023, 06:49 PM
Carlo_Carrera
Old 09-02-2023, 07:05 PM
RennKit-Dave
Basic Sponsor
Ok that will tackle the foam issue. But doesn’t seem to be a connection to the no AC issue. Will hook up Durametric and see what it says.
Old 09-02-2023, 07:34 PM
Carlo_Carrera
I think the missing foam on the blend door will effect the functioning of the AC as well as the heat.
RennKit-Dave (09-03-2023)
Old 09-02-2023, 09:22 PM
ram_g
ram_g's Avatar
Yes, but the lack of foam should lead to weak AC rather than no AC - the blend door still works, it’s just a bit porous now! I suspect there is something else going on as well.
Old 09-03-2023, 09:51 AM
griffiths
griffiths's Avatar
Toss a set of gauges on the system and read the static pressure (before you turn on the AC) and the running pressures.
If you do not have gauges, check if the outer ac compressor clutch hub is engaged and turning with the pulley.
If it is, a normal running system will have a cold return line.
The foam issue? The evap box has to come our and disassembled. Fix the foam, replace the evap core while you are at it, toss in a new drier, evac charge and test.
Old 09-03-2023, 12:37 PM
Lazurus
Lazurus's Avatar
3M heat resistant tape can be used in lieu of replacing the foam and you can cover the holes in the blend door also. It makes no difference for the functionality of the blend door flap.
I suppose the holes in the door are to allow outside air to enter. But it works either way. Replacing the heater core is good advice since you're there.
Old 09-03-2023, 04:52 PM
Scrh1
Scrh1's Avatar
Solod chanve your resistor packs on your cooling fans on the rads up front are bad. DIY on here be online to solder in new ones cheap or buy the fans and resistors and rep,ace your rads at same time if they haven’t been done yet. They aren’t cheap so depends on time / diy / budget. I opened to get new fan packs as it was less hassle and I don’t want to revisit this work in 6 or 9 months when my soldering fails. You are removing the front bumper to fox this regardless. Good luck
Old 09-03-2023, 05:51 PM
ram_g
ram_g's Avatar
This is the “correct” way to do this but expensive as the whole dash has to come out. Many people have reported success with the method referenced in posts #2 and #3 above, and I’ve also seen references to going in through the console after removing the radio and AC controller.
The foam in my ‘03 has largely blown out already but I still have reasonable AC performance so I haven’t attempted any of this in my car yet. If (when) I do, I’ll try one of the shortcut methods first before disassembling the dash.
Old 09-03-2023, 06:03 PM
griffiths
griffiths's Avatar
miss post, meant for Renne-Dave, but your comments always help.
ram_g (09-03-2023)
Old 09-04-2023, 01:14 PM
Scrh1
Scrh1's Avatar
The no ac issue is likely due to the fans and resistor packs on your radiators having gone bad or maybe just the resistors.
RennKit-Dave (09-07-2023)
Old 09-05-2023, 05:52 PM
mcwop23
mcwop23's Avatar
i have the foam issue but my AC is ice cold so I won't address it unless something changes, it has no effect on anything other than sometimes blowing a little out here and there on occasion
Old 09-05-2023, 11:57 PM
leftlane
leftlane's Avatar
I paid a local indy $70 to rectify my foam issue with a method he guarantees for life - no more foam in the last 3 years and my AC still blows ice cold.
Old 09-06-2023, 07:57 AM
RennKit-Dave
Basic Sponsor
I wonder exactly what magic he performed?
Quick Reply: No A/C and lots of foam from vents
