996 Turbo Forum 1999-2005
996/7 3D -printed Intake Distributor
Old 09-21-2022, 10:32 AM
  #46
theprf
theprf's Avatar
Received 1,645 Likes on 1,046 Posts
Which gap are you referring to? I can't measure the gap between the plenum and the oil cooler with the engine in the car very easily. I can measure the gap between the top of the plenum assembly and the roof of the engine compartment, I'll do this later today.
Old 09-21-2022, 11:25 AM
  #47
powdrhound
powdrhound's Avatar
Received 1,735 Likes on 1,011 Posts
Originally Posted by pete95zhn
OTH there's a limit with height as at some point engine bay's roof will be to close. With racres and dedicated track cars removing insulation gives some more space.
There is plenty of clearance there even with insulation. Simply not a player.
Old 09-21-2022, 11:28 AM
  #48
powdrhound
powdrhound's Avatar
So I measured the gap, it's 10mm. While our distributor with the plenum used with it is aligned with 997 turbo's parts I now know why 997 turbo has two smaller heat exchangers instead of one tall from 997 GT3. I also checked how the Y-pipe aligns with TB if distributors are taller. There's enough flex/movement from rubber/silicone couplings to allow 3-5mm taller runners. Accessories attachment points need to be lowered accordingly.
I think that we add 4mm taller runners as "race" option.
Anyway this has been very valuable item of discussion, thanks!
Pete, to clarify, does your car have the dual 997TT oil coolers or the single one like the 996 cars? The gap you measured is with respect to the dual or single cooler which is the one in question here.
Old 09-21-2022, 04:44 PM
  #49
pete95zhn
Former Vendor
pete95zhn's Avatar
Noo, I'm still using the 996 turbo's heat exchanger. I did not want to start changing consoles etc required for using 997 turbo's setup.
^^^Yes, I mean the gap between the engine's top and chassis.
Old 09-26-2022, 07:08 PM
  #50
theprf
theprf's Avatar
I slacked off on this a little bit. I just checked the distance between the top of the plenum and the roof of the engine bay and it's at least 2". I have RSS urethane motor mounts so if the stock mounts are in use, there would be even more clearance.
Old 10-02-2022, 12:12 AM
  #51
powdrhound
powdrhound's Avatar
Pete, quick question for you. Looking at your first post, you list flow data for cylinder 1,2, and 3. What is the flow on 4, 5, and 6? I don't see it listed. Thanks!
Old 10-05-2022, 05:10 PM
  #52
pete95zhn
Former Vendor
pete95zhn's Avatar
1-2-3 = 4-5-6, beause one fits both banks, just like OEM 997 turbo or GT2 ones.
Old 11-07-2022, 03:09 PM
  #53
pete95zhn
Former Vendor
pete95zhn's Avatar
There's now an introduction of this on my website, but the webshop is still in development phase. We increased the height by 5mm, so now it'll clear that taller heat exchanger too.
Old 11-07-2022, 03:11 PM
  #54
2fcknfst
2fcknfst's Avatar
Received 3,878 Likes on 2,953 Posts
I really like that black wrinkle finish on it, looks right at home.
Old 11-08-2022, 12:36 AM
  #55
powdrhound
powdrhound's Avatar
Looks great Pete. Good luck with the sales!
Old 11-08-2022, 11:23 AM
  #56
theprf
theprf's Avatar
This is exciting. I love the transparency of the development. All the data is provided as to why this is an improvement.
It's such a breath of fresh air compared to so many other "improvements", which are marked based on "trust me".
I would want one just to use the higher capacity oil cooler. Any other benefits would be an added bonus.
Old 11-08-2022, 12:39 PM
  #57
Capt. Obvious
Capt. Obvious's Avatar
Received 1,428 Likes on 784 Posts
Sorry if I missed it, but what's a rough price point for this going to be?
Old 11-10-2022, 12:07 AM
  #58
Sveach756
Sveach756's Avatar
"Available in titanium"!!!$$$$!!!! Sick obviously not for me but sick. I'll keep this in mind for when I have to do engine out service.
Old 11-10-2022, 04:03 PM
  #59
2fcknfst
2fcknfst's Avatar
Saw that... as I expect my engine to come again soon, I'm curious about pricing too.
Old 11-16-2022, 12:03 PM
  #60
pete95zhn
Former Vendor
pete95zhn's Avatar
Sorry guys...and thanks for the interest, but I've been very busy with my actual work and thus building up the webshop is still in progress. Price will be reasonable though.
Quick Reply: 996/7 3D -printed Intake Distributor
