996 Turbo Forum 1999-2005
P0410 & P1411
Old 08-10-2022 | 07:16 PM
rufrob's Avatar
rufrob
Default P0410 & P1411
No CEL but keep getting these codes and P1249. Also occasionally get a howling noise from the SAI pump on cold starts.
Guess it's time to pull and clean the pump.
Old 08-10-2022 | 10:20 PM
r6vr6's Avatar
r6vr6
forget the dtcs I had but howling SAI on cold start was toasted recirc ( blow off) valves for me.
Old 08-11-2022 | 01:52 AM
993GT's Avatar
993GT
+1, bad diverter valve(s)
Old 08-11-2022 | 02:27 AM
mffarrell's Avatar
mffarrell
Sounds like bad Diverter Valves, especially if they are honking.
Old 08-11-2022 | 05:44 AM
rufrob's Avatar
rufrob
DV's replaced.
It was a ooooooo noise and I could feel the viibration from the SAI. It was easy to pull. Some dirt came out and the hose wasn't connected.
Spent more time tying to find a dropped Allen wrench.
Old 08-11-2022 | 11:06 AM
993GT's Avatar
993GT
have you checked all the small vacuum lines? I just replaced DV's on a customer 6tt last week and the rubber connectors were literally crumbing...a vacuum leak from a vacuum hose will cause the same issue
Carlo_Carrera (08-11-2022)
Old 08-11-2022 | 11:42 AM
rufrob's Avatar
rufrob
I had the engine out last year and replaced all the rubbers. Then I did the DV the rubber hoses looked and felt good. I'll run the car a bit and see if the cleaned and properly connected SAI did it. I also had issues with TB to Y pipe boot popping off. Learnt I had to attach the boot to the y pipe first then TB. Now it stays on.
Old 08-16-2022 | 09:13 PM
rufrob's Avatar
rufrob
Finally fixed all the boost leaks getting 1.0 bar and no codes. Yippie.
I guess my ECU is tuned.
It still bucks a bit in first when starting off.
The following 2 users liked this post by rufrob:
Carlo_Carrera (08-16-2022), Scrh1 (08-17-2022)
Quick Reply: P0410 & P1411
