Too stupid: wrong Bolt removed from Gearbox
#31
I can be wrong or totally off track but I think if you got a rear end accident it will force the gearbox and motor to go under the car.... I just look at the Carrera and it is also there and call it a hook.....
http://www.autoatlanta.com/porsche-p...section=320-02
The following 2 users liked this post by jpflip:
996dougie (10-19-2023),
Carlo_Carrera (10-19-2023)
#32
#33
I was thinking that as well, but the angle is backwards. The slant of the hook faces the motor and is right up against it. If rear ended, and the entire engine and gearbox assembly begins moving towards the cabin, the backside of the hook (closer to 15 in diagram) is what will lead. So I went and looked at the chassis while everything is out and wouldn't you know it. A corresponding hook is on the chassis. I guess they interlock (as opposed to sub
Hook on tunnel support/cross member to engage hook on gearbox during rear impact
marining) and you benefit from having the strength of the cross member trying to stop the assembly and not just motor mounts/tranny mounts.
