No corner weight adjustment for stock suspension?
I am not familiar with the subject. Is it true that since the height of the stock suspension can't be adjusted, there is nothing one can do even if the corner weight of the car is out of wack?
There is no "corner weight adustment" built into the stock suspension. However, there are shims that are to be added (or removed) to properly set the ride height. While this does in theory "adjust corner weight", it is by no means as adustable as a threaded coil over system. BTW, the factory ride height has a +/- 10mm tolerance.
Cheers,
Cheers,
