Anyone have advice pls
https://www.suncoastparts.com/produc...de=996ttlights
For headlight caps, or glue it back on after using pliers to pull it out.
I dont knlw anywhere thsg sells center cap crests.
Carlo_Carrera (01-23-2021)
The following 3 users liked this post by jpflip:
As always jpflip you are the best.
Someone broke that headlight washer prior and glued it back on. Make sure to remove that glue. The new ones just press in.
here's some advice.
once you replace it. don't ever activate the washer stalk while driving at any "speed".
the shiny part of the washer nozzle will become a projectile. it only has to happen once to learn this lol
I alway think that it is just a cap only😥
Two different part# for the left and right side.....Easy to replace. Some videos:
https://www.youtube.com/watch?v=ATDECEdBRP8
https://www.youtube.com/watch?v=jU1KiBd4z_g
my car is 996 tt 2004 cab but i din’t know that it has headlight spray😅
pull the washer stalk toward you gently. it will activate the washer and a few automatic wipes of the blades.
most cars have this feature? again, just make sure you are stationary when you do it. lastly, if my memory serves. the shiny part is not sold separately and is part of the assembly noted in the graphs above. it's very simple to replace. ( and break for that matter lol ). good luck.
