996 Turbo Forum 1999-2005
Post MAF pipework mods
Old 01-19-2021 | 07:42 PM
diverzeusy's Avatar
diverzeusy
Default Post MAF pipework mods
Does anyone know of Better air intake pipework or modification on a Tiptronic, Marksi tuning, fvd, etc do kit's but they don't fit with a tiptronic transmission.
thanks 👍
Old 01-19-2021 | 07:44 PM
Bernard IV's Avatar
Bernard IV
I have the Markski soft intake pipes. They won't fit?
diverzeusy (01-19-2021)
Old 01-19-2021 | 07:47 PM
diverzeusy's Avatar
diverzeusy
Marksi tells me that they fit a manual transmission but not tiptronic, I think the problem is next to the CV joints as on a tip the CV is right where the pipes pass through, (tip has shorter drive shafts)
Old 01-19-2021 | 07:49 PM
theprf's Avatar
theprf
Having had both the 6-speed and Tiptronic engines out in the last year, I now understand the ridiculous shapes of the intake pipes. They're made to snugly wrap around the tiptronic. I also would like to find upgrade pipes for Tip cars, it just doesn't seem like there is very much room at all.
Old 01-19-2021 | 08:21 PM
Bernard IV's Avatar
Bernard IV
In that case go MAFless and run some fender type intakes.
Old 01-19-2021 | 08:32 PM
diverzeusy's Avatar
diverzeusy
yeah, thanks, that is an option but don't they get filty and dirty very quickly?
I did see a post where someone put a 'U' bend from the Turbo intake to mount a filter on each side above the intercooler, but surely that affects the intercoolers air supply and so cooling effect and would be a devil to seal airtight 🤔
Old 01-20-2021 | 07:09 PM
Capt. Obvious's Avatar
Capt. Obvious
I have a mafless tune from Markski (which I'm very happy with), and this is my setup. I did not cut into the intercooler ducts on mine, so my car just sucks ambient air from under the car (which based on logging I've done isn't an issue as far as affecting intake temps).
I run aftermarket wheels with a much lower offset than the OEM wheels, so I have more room for the pipes on my car but I think factory wheels would fit and not rub as well, but I have not confirmed this.
diverzeusy (01-21-2021)
Old 01-20-2021 | 07:23 PM
theprf's Avatar
theprf
That looks quite interesting, but I can tell you there's no way those pipes will fit with GT2 size 315/30-18's on stock 18x11 et45 wheels.
Old 01-23-2021 | 09:01 PM
diverzeusy's Avatar
diverzeusy
thanks Captions, Obvious, Could you please tell me where did you find that setup? Do you have any dimensions or part number for the filters? it does look quite tight in there 👍☺️🇬🇧🇺🇸
Old 01-24-2021 | 10:01 AM
RDS928S's Avatar
RDS928S
IMO Protomotive makes the cleanist/best fitting set up.
diverzeusy (01-24-2021)
Old 01-24-2021 | 10:37 AM
diverzeusy's Avatar
diverzeusy
Thanks for your input, I have seen these but my fears are how much this restricts Intercooler air flow, in 2 ways,
1 obviously it is located in front of the intercooler so disturbing airflow through the intercooler.
2 the filter is 'sucking' air in so = less air for the intercooler as opposed to full flow to the intercooler.
OR
Do non of my concerns make any difference?
Thanks again 👍🇬🇧🇺🇸
Old 01-24-2021 | 02:42 PM
T Kono's Avatar
T Kono
Those look like jumbo ICs, perhaps that, combined with small fans??????
Old 01-24-2021 | 05:01 PM
RDS928S's Avatar
RDS928S
5 inch cores.
Quick Reply: Post MAF pipework mods
