DSC Sport for the 996tt....
#31
The DSC Tractive package for 996TT/GT2 is not as popular as the DSC plug & play controllers for newer cars equipped with PASM, but the technology is the same. Since the 996TT/GT2 didn't come from the factory with the wiring harness for electronic dampers(like the PASM cars have) the DSC Stand Alone Kit is required as the electronic management to command the electronic coilovers. We have installed this package on 800+hp builds and on competition cars with CAN-integration. Here is one example.
I completely understand that some may feel indifferent about electronically controlled active suspension, and prefer manually adjusted coilovers. For those who have experienced the DSC plug&play controller in their 997 or 991 cars will understand what a game changer this system is. In my opinion, totally worth doing on specially-built 996TT. Basically the DSC Tractive package is injecting 20 years of electronic suspension technology into a vehicle platform that was produced in year 2000. This technology merges performance and comfort with little to no compromise.
Just helped a friend buy his first Porsche, a new-to-him 996 Turbo. It has the DSC Sport stand-alone controller and Tractive shocks installed by a previous owner. It was sold through a dealer, so some of the detail were lost in translation. i'm very familiar with 996 Turbos in general, and also run your DSC sport controller on my 991 Turbo S so familiar with that system as well.
A few questions:
- Haven't started digging around yet, but on the 996, any idea where the controller is likely mounted? Under the rear parcel shelf? In the frunk somewhere?
- Same question for the three-way controller... I realize that could likely be mounted anywhere, but anyplace in particular maybe you have in your install instructions? Are the settings basically soft, medium, firm?
- Once I find the controller and plug-in, is there a map you recommend?
- Since there are fewer inputs into the system, I imagine the tables for modifying the maps are a bit simpler than say 991 Turbo?
Thanks in advance!
It's the black car in the picture below, silver one is mine.
#32
Funny you brought this up, the DSC died in the 991 again and I'm going to swap it out tomorrow.
#33
Pretty much everything but pulling power...
Second time it's happened in less than a year.
#35
Yep, exactly.
#37
Premium Sponsor
A few questions:
DSC SA had been available for 10+ years with different mode versions over time starting with 1-mode(no button), then 2-mode and 3-mode(has button with LED to indicate modes).
Use the maps that's been in it. At minimum please save the original map. If its very old it was created on older version of the software which isn't the same version as today's.
996 CAN is far simpler than 991. Its G-force and vehicle speed only. You can adjust the Shock Cal table if you wish to change the range.
PCA National Instructor
TPC Racing stats:
2023 Porsche Sprint Challenge 992 Cup Am Champion
2023 Porsche Sprint Challenge GT4 Pro-Am Team Champion
2022 Porsche Sprint Challenge 992 Cup & 991 Cup Champion
2020 IMSA GT3 Cup Challenge 2nd Championship
2018 IMSA GT3 Cup Challenge 2nd Championship
2016 IMSA GT3 Cup Challenge Champion
2013 IMSA GT3 Cup Challenge Champion
2006 Rolex-24 @ Daytona GT Champion
2004 Grand-Am SGS Class Champion
TPC Racing stats:
pfbz (04-10-2023)
#38
Since the DSC SA(StandAlone) controller kit for pre-PASM cars is a customized installation using a universal wiring harness there's no set location to put the controller. Depending on who installed it the installer will have there prefered location. I would guess that its near the ECU area.
We found the button, it appears to be the three mode (single button and led). Huge improvement!
It seems to default back to map 0 on ignition cycle, I assume there is no way to change what map is loaded by default? The current default map is definitely too soft for the new owners preference.
#39
Premium Sponsor
Thanks Tom for the follow up!
Its possible that this kit was made before the G Comfort Parameter feature was introduced, so it'll be wise to save the file, and only make changes to Shock Calibration table.
