996 Turbo Forum 1999-2005
Service cost
Old 10-03-2020 | 05:45 AM
tokmane's Avatar
tokmane
Default Service cost
How much should a service that includes engine and transmission fluids and filters cost?
last service was 30K at 30K but that was 2 years ago so even though the car has only 33K miles today, I believe it needs to be serviced.
2005 996 turbo tiptronic S.
Thanks!
Old 10-03-2020 | 08:42 AM
pancing's Avatar
pancing
Thanks!
Last time i had mine serviced at indy it was about 900 or so for brake fluid, transaxle, front diff, oil change.
Old 10-03-2020 | 10:04 AM
Carlo_Carrera's Avatar
Carlo_Carrera
Dealer or indy?
Old 10-03-2020 | 08:45 PM
Dock's Avatar
Dock
I don't think you need to change the transmission fluid after two years and 3K miles.
Old 10-03-2020 | 08:49 PM
911mhawk's Avatar
911mhawk
Oil change and +200 for brake fluid flush.
Old 10-13-2020 | 12:10 PM
lflouie's Avatar
lflouie
The extent of the fluids service may or may not include a coolant flush if more than 6 yrs old. This can add at least $250 for fluids and labor. Are you planning to flush all of the Pentosin including steering and clutch as well brake slave/master cylinder fluids. These could easily add another $250.
if it is just engine oil/filter, brake lines and transfluid and diff then under $1000.
Old 10-13-2020 | 12:12 PM
lflouie's Avatar
lflouie
Duplicate
Old 10-13-2020 | 12:44 PM
911mhawk's Avatar
911mhawk
Do the Pentosin when the slave/accumulator fails or the PS unit starts whining.
Haven't seen anywhere on a maintenance checklist/schedule from Porsche where they mention any more than checking it. Probably because they knew the other parts seals would fail before the fluid.
It is used in other systems like hydraulic tops where it never gets changed, until of course those parts fail and you need to add some...
