996 Turbo Forum 1999-2005
b&m ssk
Old 03-15-2004 | 04:09 PM
Sun Ra's Avatar
Sun Ra
thank you Mr pants!!!! you are most kind.
Old 03-15-2004 | 04:42 PM
Tool Pants's Avatar
Tool Pants
No dealer is going to want to do this. They will want to put in a new shift tower.
Old 03-15-2004 | 05:59 PM
W8MM's Avatar
W8MM
This thread is quite interesting.
I just had a B&M short shifter (bought from Evo, along with their metal cable end) put in my '04 TT cabriolet.
I like it better than the stock shifter because it seems to reduce the uncertainty of which gear is being selected. Perhaps I'm peculiar, or have imperfected shifting technique, but the B&M is pretty nice AFAIAC.
Some older BMWs and a Triumph TR-3A were among the better shifter feels I have experienced over my nearly 40 years behind the wheel.
Porsches that shift well is an oxymoron to any early 911 driver. The IROC car was a little like stirring a keg of nails with a broom stick! The 996 shifter is soooo much better, but the short shifter in my car is better yet. The only imperfection is a slighty too high effort, but it is more than overcome by the improved confidence of finding the correct gear in a hurry.
YMMV,
Old 03-15-2004 | 11:30 PM
Sun Ra's Avatar
Sun Ra
mike you dont get it because B&M makes sense in a TT, not in a GT2 which has a much better shifter
Old 03-16-2004 | 03:01 AM
Steve in FL's Avatar
Steve in FL
watt: I wonder how much of the different feel for the GT2/GT3 shifter is the transmission rather than the shifter? Porsche refers to the GT3 trans as "evolved" from the GT2 transmission so they aren't identical but I think they're somewhat beefier than the stock TT gearbox and definitely stronger than the standard 996 trans.
Old 03-16-2004 | 10:20 AM
W8MM's Avatar
W8MM
OK, watt.
I guess I must not have been able to figure out when/where the subject changed from 996 to GT2. I thought Colm was talking about a 996 as compared to the feel of a GT2 (different car?).
Old 03-16-2004 | 01:10 PM
marlborough's Avatar
marlborough
New User
Mike,
Both Colm and Watt seemed to be referring to GT2's so it seems apropos.
In my GT3, the shifter is great and I think it's the same as a GT2. I did notice it was better than a TT and a 996 I drove once
Old 03-16-2004 | 01:34 PM
W8MM's Avatar
W8MM
Originally posted by Colm
Installed in my 996, was really unimpressed with it and took it out, going back to stock.
The above is where I must have gone wrong.
Watt, it's cool. I can get on with it OK now.
Old 03-16-2004 | 01:38 PM
Sloth's Avatar
Sloth
In the GT2 and GT3, the shifter is supposed to be ~15% shorter than the standard Carrera and TT shifter. I installed the B&M in my GT3... that is one shortshifting tranny. Shift effort and notchiness has increased, but the shifter feels very direct and very short.
Old 03-16-2004 | 02:16 PM
Tool Pants's Avatar
Tool Pants
Our local group put in the B&M in Colm's 996 last year. He also has a GT2. Colm told me he thought his GT2 had some type of short shift kit in it from the factory. It does not. But it does have a different transmission.
I have measured the throws on a stock C4S and a stock GT2. The "difference" was 3/8". Due to the play in the in the system the throws could be identical - it depends on how you measure. As far as I am concerned the throws on a 996 and a GT2 are identical. I do not know where 15% comes from. The Boxster special edition has a 15% shorter throw than a normal Boxster - but that is because Porsche cut 1" off the shift lever.
When I get my hands on a Turbo and a GT3 I will measure the throws.
Old 03-18-2004 | 05:26 AM
limitup's Avatar
limitup
4 3/8" ... damn that is a long throw. Just IMO of course. A properly adjusted B&M is a whole lot better than that if you ask me. The increased resistence you get used to, no big deal. I could never get used to the stock shifter ... it just doesn't belong on this type of car if you ask me.
Old 03-18-2004 | 03:52 PM
TT Gasman's Avatar
TT Gasman
The reason they use the cheap plastic shifter in these cars is 95% of the drivers are fine with it and never complain. It's just the small enthusiast population that wants a better shifter, so they repackage a $200 shifter and sell it for $700. You don't get to be the most profitable car company giving the good stuff (GT1 based engines etc) away.
Old 03-18-2004 | 04:12 PM
Tool Pants's Avatar
Tool Pants
On the C4S the throw was reduced to 3".
Old 03-19-2004 | 08:58 AM
Jmac's Avatar
Jmac
Toolpants - was the 3" reduction on the C4S with the B&M SSK? I was planning on installing one on my C4S Cab (due to arrive in a few weeks), but frankly, after reading this thread, I'm totally confused as to whether or not it's worth it...
Old 03-19-2004 | 02:15 PM
Tool Pants's Avatar
Tool Pants
We put the Porsche unit in on that C4S but the Porsche unit is identical to the B&M. I suggest people try it out first to see if they like it.
Quick Reply: b&m ssk
