996tt FWD
unless you install either a TBD or plate type LSD you will "occasionally" expose your car to "one wheel drive" scenarios by eliminating the awd.
you will hate that, when it happens when under certain more extreme driving conditions. for tooling around the street, you probably won't notice anything untoward.
THP23 (06-26-2020)
k9turbo (06-26-2020)
The steering feel is much nicer, just go drive a 2wd 996/997 tip to sample and try it out w/o actually doing anything.
I converted my old C4S to rear wheel drive, and my Turbo is currently RWD because I pulled the cardan shaft to dyno it a couple months ago and decided to leave it out for a bit.
I'm going back and forth on whether to put the AWD back or not. On the C4S it was great and I preferred it that way, but with nearly double the power in the Turbo I'm inclined to keep it AWD until I can get around to installing a LSD.
I also still have the pipe dream of installing a front diff from a 997.2 and finding out some way to control the clutch pack in it (I think the bias is controlled by either a 0-5v signal or a 0-12v signal but haven't been able to confirm).
Nope, drives totally normal. The steering is a tad lighter and that's about it. There are no sensors or electronics associated with the AWD on these, so the car has no idea whether the AWD is there or not.
That's pretty neat - one would think that the front drive shafts, CVs, hubs would all detract from the overall steering feel - unless of course, you pulled that as well.
Are you going to leave it as such? Is there a benefit to going to GT2(Phenix) uprights at the front and go all the way to 2wd permanently? Must say, I would be curious to try one that has been converted.
