New error codes
New error codes
My check engine light came on so i went to trouble shooting option on my Cobb accses port.
P0103= mass airflow sensor
P1156 & 1145 = 02 sensor bank 1 & 2
P0601= DME relay module fault (computer monitoring reset)
P1136= Charge pressure comparison sensor .
The motor has heavy mods & is custom tuned so the P0601 fault code is not relevant-so im told.
What a mess though- Should i replace 02 sensors & MAF just in case?
RDS928S (06-22-2020)
if youre running high boost you need to use the waffle behind the venturi on that intake otherwise youll blow mafs with turbulent air. From what i ive read anything over 550 hp or so will need the air straightener from the stock airbox. Install the waffle, clean the maf reset codes then see if they come back. If they do, replace maf sensor, it might be all youll replace, ur o2 code is a rich code so it doesnt relate to o2 being bad.
RDS928S (06-23-2020)
That box was known for blowing MAF's. Evoms came out with a waffle screen to prevent it from happening, but that is your issue I'll bet. So as suggested above go Mafless, ditch the Evoms box or contact EVOMS for the waffle screen.
