The only one I have ever hit was previously hit and lying across the highway in pitch black conditions; when I finally saw it and got on the brakes, I hit it at about 40mph and went airborne (was driving a truck).
Scared me silly, bent a whole whack of stuff, but we made it to Vancouver.
I'll be sure to update you if I have any issues. Not much grip in the General Max RS's so you might be right, but diameter is identical, even with the 2k I have on the front tires.
fk510s, they work well. I don't plan to use these on track though.
I figured, and agreed, they're not for the track. I bought my car back in 2014 and it has FK 452s up front and new 453s out back. PSM wasn't happy, swapped out the fronts for new 453s and all was good for about 6000 miles, but the rears didn't age well and lost grip on my canyon runs well before they were worn. They were a fine street tire, assuming the new 510s will be even better. I'm probably 1000 miles in on the new Contis and they're doing well, quiet, good ride quality, and sticky in the canyons...
Quick update, I have the fk510's on order, and will be running mismatched front/rear until I want the General Max RS's gone in the front.
I am not a fan of doing that because the rubber is not only from different manufacturers, it will also have different adhesive qualities - so be careful pushing it.
