The Ultimate Diverter Valve (DV) Upgrade is here from APR
Premium Sponsor
APR R1 Diverter Valve (DV) Now Available for Multiple Porsche Turbocharged Engines
http://goapr.io/r1
http://goapr.io/r1
http://goapr.io/r1
We are pleased to announce the world famous APR R1 Diverter Valve (DV) is now compatible with multiple Porsche turbocharged engines! This announcement comes after more than a decade of successful operation on thousands of vehicles worldwide!
The APR R1 DV is a critical performance upgrade recommended at all stages of performance as it replaces the failure prone factory unit. The R1 is designed to withstand extreme boost pressures at the highest levels of performance, while offering lightning fast response thanks to the unit’s friction-free diaphragm-based design. Unlike piston based units that can stick and bind in the winter, the APR R1 is virtually maintenance free, requiring no greasing or o-ring replacements, as is common with other units. Constructed from CNC-machined billet-aluminum with a high-temperature Nomex-reinforced diaphragm, the R1 is designed to be the last DV upgrade the engine will ever need!
This unit generally replaces the factory "710" piston style DV which has 1 inch inlet and outlet hoses, and will look physically similar in shape. It's not designed to replace an on turbo DV, both manual and electronic, as found in the 997.1 Turbo, and latest generation Panamera 2.9T/3.0T/4.0T and others, both of which look dramatically different in physical shape and appearance.
Part and Price
Porsche Application Guide
Twin Turbo Setups Require 2
Buy Now
http://goapr.io/r1
http://goapr.io/r1
http://goapr.io/r1
http://goapr.io/r1
Part and Price
- DV100001 - $159.99 - Free Shipping
- Porsche 911 (964) 3.3T / 3.6T
- Porsche 911 (993) 3.6T
- Porsche 911 (996) 3.6T
- Porsche 911 (997.2) 3.6T / 3.8T
- Porsche 911 (991.1) 3.8T
- Porsche 911 (991.2) 3.0T / 3.8T
- Porsche 944 (951) 2.5T
- Porsche 718 Cayman / Boxster (982) 2.0T / 2.5T
- Porsche Cayenne (9PA) 4.5T / 4.8T
- Porsche Cayenne (92A.1) 3.6T / 4.8T
- Porsche Cayenne (92A.2) 3.6T / 4.8T
- Porsche Macan (95B.1) 3.0T / 3.6T
- Porsche Panamera (970.1) 4.8T
- Porsche Panamera (970.2) 4.8T
Buy Now
http://goapr.io/r1
GoAPR.com | Facebook | YouTube | Twitter | Instagram
Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
Premium Sponsor
Duc Hunter (01-19-2020)
When I got my car it had the straight up nipples coming from the top of my Bailey DVs and it eventually rubbed the body and cut the vacuum line. I switched them out for 90 degree nipples and haven’t had an issue in the last 3 years.
Duc Hunter (01-24-2020)
