996 Turbo Forum 1999-2005
Coolant Leak / Pinning / Welding Question
Old 01-08-2020, 08:44 PM
  #31
Mike Roblin
Mike Roblin's Avatar
No PCA restrictions down in So Flo either.
Old 01-08-2020, 09:06 PM
  #32
manimal
manimal's Avatar
Originally Posted by SOS
​​​​I'm not the preachy type. I normally don't give an F what other people do with their cars, but thinking about it now, maybe securing your coolant pipes is your responsibility for safe motoring not just for you, but everyone around you.
+1 on this.
I wouldn't do big track days without them pinned or welded based on the Golden rule, regardless of PCA rules.
I'm already relieved that I didn't make any enemies at the AutoX when mine went.
Old 01-08-2020, 10:11 PM
  #33
2fcknfst
2fcknfst's Avatar
Received 4,145 Likes on 3,137 Posts
If I were behind Twinturbofan and that happened to me, at speed, after changing my shorts, I am fairly confident that I would have been less than impressed, especially since it is a known preventative maintenance issue.
Good thing I don't go on the track.
Old 01-08-2020, 11:51 PM
  #34
Turbodan
Turbodan's Avatar
Originally Posted by pfbz
It isn't an issue with the PCA regions around here... We have plenty of rules, but that isn't one of them.
I recall a few years ago this was a policy from PCA national, not region specific. Maybe not all regions enforce it but up here it is on our tech form. Most other groups up here have the same rule for Metzer engines. Or you can use water wetter instead of antifreeze(pca allows this, as it is not nearly as slippery) and most race cars run this I believe. I wonder if powderhound runs water wetter?
Old 01-10-2020, 12:45 PM
  #35
Spyerx
Spyerx's Avatar
Received 1,817 Likes on 1,107 Posts
I'm really surprised this is even still a debate. ANY owner of a Mezger engine needs to have this done. ALL of these will fail at some point. You might get lucky and just lose coolant, you might cause a car crash, you might crash if you're on the race track, or cause others to hit the wall.
You can reach @BBiAutosport regarding their cost to clean, weld, and test the fittings using their pipes. I bought a few sets of their pipes for friends and want to say they were about $300 at the time. Not sure now, that was some time ago.
manimal (01-10-2020)
Old 01-10-2020, 01:04 PM
  #36
s65e90
s65e90's Avatar
The only guys still debating it are the one's who having done it and they're looking for inner peace, lol.
Old 01-10-2020, 01:28 PM
  #37
Turbodan
Turbodan's Avatar
its like the guys on the 996 board convincing themselves their M96 is a good one and not going to fail
The following 2 users liked this post by Turbodan:
Mike Murphy (01-10-2020), nerdtalker (01-13-2020)
Old 01-10-2020, 02:15 PM
  #38
Spyerx
Spyerx's Avatar
Pretty much, done 100s of track days and seen at least a dozen of these fail...
Horrible engine design. I'll never own one.
Old 01-14-2020, 03:36 PM
  #39
cgfen
cgfen's Avatar
Originally Posted by ipman
What does BBI charge to weld up their coolant pipe kit, assuming you send the parts to them?
So much easier to contact BBI and ask them for current pricing.
but
They quoted me ~ $650 18 months ago.
Old 01-15-2020, 08:09 AM
  #40
aabueg2005
aabueg2005's Avatar
I know this is for the 997 tt, but its the same engine. Engine is out currently and had a long list being done as we speak. It may help you decide what other things you can do while fixing the coolant pipes.
https://rennlist.com/forums/997-turb...ent-today.html
Old 02-10-2020, 09:26 PM
  #41
Skyman911
Skyman911's Avatar
So, what actually happens when you blow a coolant line from the glued connection? I know there will be a lot of steam and sudden loss of coolant. Are there any parts subject to damage? Anything to look for on a car that had blown a coolant fitting and had them welded? The guy spent almost $8K on the repair.
Old 02-10-2020, 09:47 PM
  #42
Giovanni
Giovanni's Avatar
If there was damage when it happened due to sudden rise of temperature, then you will know by listing to the engine run or when driving the car. I am sure at that point there will be ticking noise, power loss, ongoing overheating issues, probably a busted head gasket, etc. Possibilities and speculations are endless. If the engine sounds healthy and has good power then more than likely there are no hidden damage or anything catastrophic waiting for you. But it's the risk that we all run whenever we buy used cars.
Old 02-10-2020, 10:07 PM
  #43
2fcknfst
2fcknfst's Avatar
Come to Canada - the fix is only $3k CDN...
Old 02-10-2020, 10:54 PM
  #44
Carlo_Carrera
Carlo_Carrera's Avatar
Received 2,536 Likes on 1,605 Posts
$3k CDN for welding the pipes?
Old 02-10-2020, 11:00 PM
  #45
Giovanni
Giovanni's Avatar
Y'll throwing me off (lol) when you state "price for welding the pipes". Welding the pipes don't cost much, the real cost is involved in removal of the engine and all other components and to put it all back together.
Quick Reply: Coolant Leak / Pinning / Welding Question
