996 Turbo Forum 1999-2005
DIY: Installing 997.2 GT2RS Intercoolers
Old 06-26-2020, 06:50 PM
pfbz
pfbz's Avatar
Received 2,878 Likes on 1,531 Posts
Originally Posted by tekkie
I think i owe you some
Just let us know if your 2001 had mounting rack/intercoolers like mine or the later style?
Old 06-26-2020, 07:59 PM
2fcknfst
2fcknfst's Avatar
Received 4,174 Likes on 3,153 Posts
Just out of idle curiosity, how much time was involved in the above modification, roughly?
Old 06-27-2020, 12:27 AM
pfbz
pfbz's Avatar
Lots of hours pondering exactly what needed to be done, not so many actually doing it!
Aside from the time needed to remove/replace the rear bumper and intercoolers (as you would need to do for a spark plug change), and doing it again, I could probably modify the ducts, mate up the new intercoolers, and have them ready to be re-installed back in the car in less than an hour a side.
I also made a few changes from the above... After modifying all the clips, i abandoned that method. It is time consuming and finicky... medium-duty zip ties work perfectly. Remember that the clips and zip ties only hold things together until they are back in the racks and back in the car. Once fully installed, everything is sandwiched together with the bumper cover and isn't going anywhere.
I also abandoned the flat sheet metal extension plate... IMHO it works better if you just trim the ducts to fit without the plate and just use some strategically placed weatherstrip. Since i had my new intercooler assemblies apart and together several times trying to figure out why the hell they didn't fit, I streamlined a few things for the better.
Old 06-27-2020, 12:45 AM
pfbz
pfbz's Avatar
Here are some additional pictures from my install. The last few are of the small bracket that is only needed on some or all 2001s
Old 06-27-2020, 01:24 AM
2fcknfst
2fcknfst's Avatar
It is that and the fabrication of components I am curious about - I will then calculate an hourly rate to define what the real costs of the job were.
I am wondering if it comes close to to the value of buying a set of those Marstens (apologies if I spelt that wrong), because if it does, then it makes it easier to justify the purchase.
Old 06-27-2020, 01:42 AM
tekkie
tekkie's Avatar
will do for sure
Old 06-27-2020, 04:24 AM
911mhawk
911mhawk's Avatar
Very helpful piece, I just replace the zip ties when I do plugs every 5k or so.
Old 06-27-2020, 02:15 PM
TrillyPop
TrillyPop's Avatar
Dang those last 10 posts included a lot of effort by pfbz...
My car is a 2001 and I also could not use either of the front/lower mounting points. I also agree that zip ties are the way to sandwich the upper and lower ducts together. Modifying the straps is a lot of unnecessary effort. With zip ties and only the 2 rear mounting points, it's extremely stable and those intercoolers aren't going anywhere.
Old 06-27-2020, 02:26 PM
pancing
pancing's Avatar
If only people knew how many zipties we use on our cars lol...
The following 2 users liked this post by pancing:
pfbz (06-27-2020), s65e90 (07-23-2020)
Old 06-27-2020, 04:31 PM
docwyte
docwyte's Avatar
I know we talked a bunch about modifying the clips vs zip ties. Either are fine but I'm glad I have the modified clips on mine. This is not a quick job, between taking everything apart, modifying the shrouds, clips, etc, putting the intercooler assemblies back together and then putting the car back together I bet I had 10 or more hours into it.
Of course now that I've done it once and have all the pics, measurements etc to modify the shrouds I could probably cut that time in half. Assuming I didn't have to make mods to the brackets like Paul did...
Old 07-10-2020, 11:45 PM
tekkie
tekkie's Avatar
it finally cooled down a little so I got the driver one off and yes my 2001 has the same issue you posted, heading to ace hardware in the morning to get some metal
Old 07-23-2020, 12:44 AM
Xaerran
Xaerran's Avatar
Where are folks sourcing their new intercoolers from? Thanks
Old 07-23-2020, 09:58 AM
docwyte
docwyte's Avatar
autodocuk.com
Old 07-23-2020, 10:36 AM
s65e90
s65e90's Avatar
Get a set of 4.5" bell cores and you have excellent intercoolers for a little more money.
Old 04-07-2022, 10:07 PM
jcc0016
jcc0016's Avatar
I am in the process of doing this mod now and in putting the first (passenger) side back in, I could not get the bracket mounted back onto the car. That’s when I realized, I had the early style bracket. When I pulled the IC out of the one mounting location, I could get it all to line up.
My question, what did you use and how to fabricate the extension?
Quick Reply: DIY: Installing 997.2 GT2RS Intercoolers
