Injectors
All in all it took me about 8 hours of labor across 2-3 nights to do both sides.
Originally I pulled them out to upgrade only to find out my car already had upgraded injectors. So I sent the injectors off to be cleaned and balanced.
This is the cool sheet that the place that cleaned and balanced the injectors provided. The car had ~60,000 miles on it when I sent the injectors off to be cleaned. Keep in mind the injectors weren't stock so they would have had even fewer miles. Just goes to show that they do build of grime which reduces spray/flow over time.
After I saw the state of the fuel filter, I planned to do them when the engine was out for clutch/slave/pinning, and NOW, I am cognizant that the fuel filter should be changed more often than every 15 years...
blazen244 (01-23-2021)
I was impressed with them, the person I dealt with was very friendly and provided regular updates on progress. I think they had them back to me in a couple days. I wouldn't hesitate to send a set to them as part of routine maintenance on a car assuming the injectors were easy to get to. I typically buy used cars, something like this seems like a good way to establish a good maintenance baseline.
That was my point.
2fcknfst typing out,"Factory units are about $70 Canadian per; just replace them and save yourself the hassle - the car is getting on for fifteen plus years old...." Is simple to do, actually replacing the injectors? Not so simple to do.
Counterpoint - unless he plans on tossing on a set of winter tires, the car is going to be out of commission for the next 4-5 months. Why not use this time to peck away at getting her back to top running condition? If you can swap plugs on this car you can do injectors. it's not technically challenging, its just requires patience and the helping hand of the wife and/or toddler.
Won't be putting on snows, but will continue to drive it over the winter - the one (or two days) it snows in Van, I'll drive something else.
The siemens 60lb is a nice upgrade and dirt cheap. I would highly recommend anyone running even a mild tune consider moving to the 60lb if they're going to pull injectors. They're not some massive injector that will cause idle issues, but they are a nice jump in capacity to bring your duty cycle down.
This listing is Sam's, I'm sure you could squeeze a black friday deal out of him.
https://www.ebay.com/itm/Porsche-996...EAAOxyZw5RbhlY
Yes, $100 per is not a bad price for an uprated injector. Now, if only direct injection diesel injectors were that cheap...
Thanks guys will run the cleaner through first and see what happens just looking at the coils they look to be recently replaced and the studder isnt bad at all I've had worse from my E65. That was in need of 0lugs and coils and still ran the cleaner she's running like new.
Ive got a whole lot of updating on the car before i think of doing injectors again.
Whats a the duty cycle of stock injectors?
i calculated mine at around 70 to 72% at 6600 rpm for 3 logs in 4th gear.
Fuel system cleaner
Fuel filter
Plugs
Coils
Injector connections
Injectors
