Lost my tune. Is my car still safe?
So my car originally had an unknown tune done by a previous owner many years ago. Due to some electronic issues, my ecu recently had to be reflashed back to stock. My car has k16/24 hybrid turbos, exhaust with 100 cell cats, upgraded diverters, boost controller, and evoms headers.
I plan to eventually re-tune the car, but over winter/spring I'm planning on doing some hardware changes so I'd rather do the tune after.
So is my car safe to run on the stock tune with these components? I also plan to do a couple of autocross and winter track days before getting to the re-tune stage. Should I worry? As it is now with the stock tune, the car will boost to 0.8 bar, but I have no data logging capability so I don't know what's going on inside. With the old tune it would safely boost to 1-1.1bar.
Also, anyone know if any of the Cobb OTS tunes would safely work with my setup for now? I see Cobb units are 10% off right now. If I could buy an Accessport, use the OTS tune for now, then get a custom tune in summer, I'd be happy.
Thanks.
Thanks.
Buy the Cobb; it'll work well with your setup, it's what I run.
Once I have finished fiddling with mine, I will have some more focused tuning done to tighten it up a bunch and optimize power/drivability.
SOS (11-18-2019)
SOS (11-19-2019)
if you have injectors, you cant run the car. afr will be off, rich if you have bigger injectors. I wouldn't drive a car at all with the wrong tune on it. Just do what everyone above said and talk to your favorite tuner and get it fixed. run rich and foul some plus = pain in the *** to change them all. run lean and maybe blow up your motor even without the boost. Sounds like lose/lose.
Send me a email and we can get a plan for your tuning. the first thing is to datalog and set the benchlines. At idle and on the road..
If you were running large injectors you would be running pig rich. Your idle would be all over the place.
You also need to make sure that you have a stock MAF a Hitachi MAF will wreck your fueling.
