996 Turbo Forum 1999-2005
Lift Question
Old 07-18-2019, 01:52 AM
  #31
sgtpeper
sgtpeper's Avatar
Nice!
I ended up raising the framing 18" to allow the list to work properly. Now wiring for a side scroll garage door for that bay as well as 220 for the lift and another 220 for my electric Jaguar charger. I'll have more pictures as the garage gets closer to completion!
Old 07-18-2019, 01:47 PM
  #32
pfbz
pfbz's Avatar
Received 2,722 Likes on 1,463 Posts
Originally Posted by sgtpeper
Nice!
Nice!
AC? My detached garage gets plenty hot in the summer, right now just running a freestanding AC but will eventually put in a split system ductless... Not really needed for just storage and parking, but awesome if you do any work in the garage.
Old 07-18-2019, 02:38 PM
  #33
jsimon777
jsimon777's Avatar
My 3 car garage is normal 100 in the summer and maybe gets down to 85 at night. How well do you think a split system would work in a garage my size? 30'x20'x9'. Expensive to run?
Originally Posted by pfbz
Nice!
Old 07-19-2019, 02:57 AM
  #34
pfbz
pfbz's Avatar
Split systems come in different btu/ton capacities, should be no problem getting one capable of dealing with 600 s.f. Probably a 1-ton system which is on the low end capacity wise.... They are also usually pretty high efficiency (SEER rating) so they actually cost less to run than typical ducted AC, and there is also no loss through ductwork.
Old 07-19-2019, 03:09 PM
  #35
my04996tt
my04996tt's Avatar
Mitsubishi sells a line called Mr Slim wall mounted systems. I've spec'd some for work with very good results. They have run for years with no issues, quiet and efficient.
Quick Reply: Lift Question
