996 Turbo Forum 1999-2005
Current alternatives for hydraulic clutch conversion to non hydraulic.n
Old 02-06-2020, 02:16 PM
euro850r
euro850r's Avatar
Originally Posted by manimal
The benefit is that it doesn't depressurize the system, so if you have a leaky/failing slave, it maintains more consistent pedal feel.
When the clutch is depressed, even with the car off, the slave assist loses pressure. That's why some folks experience a moving/inconsistent engagement point. It definitely drove me insane, personally, feeling as if I had forgotten how to drive stick.
First modification I made to the car was to remove the assist. I was pretty embarrassed on my initial test drive with the previous owner and I've had manual cars for 20 years.
Old 02-06-2020, 02:23 PM
manimal
manimal's Avatar
I'm getting my car back soon from having the GT2 conversion installed. Can't wait.
Old 02-06-2020, 02:43 PM
jumper5836
jumper5836's Avatar
Originally Posted by 2fcknfst
Straight across factory GT3RS4.0 clutch kit, not modified.
ok then if you still have the stock help spring your clutch is as heavy as mine. I been told it feels like a GT3RS clutch. I just noticed that my non assist 996 C4S clutch is so much lighter then the Turbo now where it used to be the other way around.
Old 02-07-2020, 11:39 PM
pfbz
pfbz's Avatar
Received 2,748 Likes on 1,475 Posts
The heavier clutch feel of the GT2 setup is perfect when driving aggressively or semi-aggressively, though a bit of a pain in the *** during rush hour stop-and-go traffic. I personally could never go back to the wonky, inconsistent stock hydraulics. I have a full factory-style GT2 conversion as well as the GT2 clutch pedal spring.
Old 02-08-2020, 12:41 PM
jumper5836
jumper5836's Avatar
Thanks I assume 996 GT2 clutch pedal spring. Looks like I will need to install that as well.
looking seems part number is 99642308119
Old 02-08-2020, 12:56 PM
lflouie
lflouie's Avatar
Default Spring
I have a brand new unused 99642308119 GT2 spring. For sale: $70.00 shipped in lower 48. Just pm if interested.
Old 02-08-2020, 01:52 PM
jumper5836
jumper5836's Avatar
too late already bought one online, also I was the person who bought the bbi off you and got the clutch spring that doesn't fit on a 996tt (997423081)
Old 02-08-2020, 02:07 PM
lflouie
lflouie's Avatar
Default Spring
Sorry to hear that, wished youd contacted me so we could have fixed your issue. The spring sent was the one I bought from BBI, but had this one as a backup. Hoping you like the system works.
Old 02-08-2020, 02:15 PM
jumper5836
jumper5836's Avatar
np, I am sure I will like it once the spring is installed
Old 05-29-2020, 07:44 PM
jumper5836
jumper5836's Avatar
Just got it installed, it is much better now. I actually can't tell it it was done anymore it feels normal like my 996 C4S clutch but a tad heavier.
Quick Reply: Current alternatives for hydraulic clutch conversion to non hydraulic.n
