Current alternatives for hydraulic clutch conversion to non hydraulic.n
What are the current alternatives for hydraulic clutch conversion to non hydraulic?
For the most comprehensive Kit" is the factory installation of GT2/GT3 clutch slave components. Go to my clutch page and look at the hardware involved.
http://ultimatemotorwerks.com/clutch.html
You can remove the power steering pump BUT in my opinion I strongly recommend adding the new reservoir.
Am I missing something from the OP? The difference between the standard TT clutch and the GT2 is the TYPE of hydraulic fluid (one is Pentosin the other some DOT4 equivalent). None are non-hydraulic TMK!
The difference is elimination of the clutch assist/accumulator which dampens the clutch action and can be in consistence on engagement point feel.
But if you mean improvement over the stock 996 system, it usually goes like this:
- Stock System. (Power steering pump boosted pentosin)
- Stock System with clutch switch removed to allow clutch-out stand and improve consistency.
- Stock System with fresh slave and accumulator.
- GT2-like setup with third party bracket. (non-Pentosin)
- True GT2 conversion with OEM GT2 reverse shift fork, slave, and pedal spring.. Drill/tap the alternate mounting bosses on the transmission, (non-Pentosin)
If you really mean non-hydraulic, you will need to go back to an air cooled 911...
So I ended up doing the BBI Clutch Slave Cylinder Conversion. Anyone else have had it done?
I also have a upgrade clutch and pressure plate so it has more pressure then oem. Now the clutch is very heavy and I am looking at how to make it a little less. I got the kit with a clutch spring from what I think is a 997gt3 (997423081) bu it doesn't fit and is too large to install.
Would the 996 GT2 clutch spring (996423081) fit in a 01 Turbo?
I Did the BBi conversion and Kevin's GT3RS clutch/PP - I love it and I don't find it very heavy at all.
Mind you, my left calf is easily three times bigger than my right one...
I also have a upgrade clutch spring so it has more pressure then oem. Now the clutch is very heavy and I am looking at how to make it a little less. I got the kit with a clutch spring from what I think is a 997gt3 (997423081) bu it doesn't fit and is too large to install.
you have a 996 tt with the 997 gt3rs clutch helper spring? My mechanic couldn't fit it on my car no room to install it.
Tell me more about this, I'm not familiar with this idea. Does the clutch switch have something to do with how much assist there is? I thought it was just a safety switch for starting the car?
The benefit is that it doesn't depressurize the system, so if you have a leaky/failing slave, it maintains more consistent pedal feel.
When the clutch is depressed, even with the car off, the slave assist loses pressure. That's why some folks experience a moving/inconsistent engagement point. It definitely drove me insane, personally, feeling as if I had forgotten how to drive stick.
