996 Turbo Forum 1999-2005
Wheel studs or factory wheel bolts
Old 03-20-2019, 11:59 AM
993GT
993GT's Avatar
pretty well documented that the factory bolts are more durable than most of the stud kits in real world use
Old 03-20-2019, 01:09 PM
03EvoIII
03EvoIII's Avatar
Originally Posted by jdexter
I just ordered some studs. Like everything, powdrhound has already posted on this with the porsche motorsport information. H&R 1454005 is the part number for what you want. They install with 32 ftlb of torque to the hub. Then get the steel lug nuts. They need 118 ft lb.
Awesome! Thanks for posting this. I ordered the rennline stud/nut kit. I assume I can use the same torque specs.
Old 03-20-2019, 01:15 PM
HenryPcar
HenryPcar's Avatar
Originally Posted by Ogr8frogy
So the question is what do you prefer wheel studs or the factory wheel bolts?
I went to studs on my c2 and it was nicer using them
but my turbo has the PCCB’s.
Is it wise to stay with the factory bolts or can I use the studs with my brakes.
I think it would be easier using the studs in the sense of not hitting the rotors trying to put the wheel on. I know to use the guide pins but I’ll looking to see if there is any draw back to doing so with the studs.
I have not found anything in a search either.
So all and any input would be appreciated
Bolts, especially with spacers and after market titanium bolts. You save quite a bit of weight using titanium bolts because the entire bolt and threads are Ti and is stronger than steel.
Old 03-20-2019, 01:32 PM
Dock
Dock's Avatar
Old 03-20-2019, 01:38 PM
Third-Reef
Third-Reef's Avatar
The Ti bolts are some nice jewelry to put on the wheels and they save about a pound per wheel. Mine have been good durability wise with many wheel on/off events for brake bleeding and suspension upgrades. World Motorsports have the best prices.
Old 03-20-2019, 01:48 PM
jdexter
jdexter's Avatar
I think titanium is a no-no for race applications. Titanium is not as strong as steel for this application.
Old 03-20-2019, 01:55 PM
Carlo_Carrera
Carlo_Carrera's Avatar
Received 2,236 Likes on 1,442 Posts
Every professional race team in the world uses studs.
Old 03-20-2019, 02:01 PM
Dock
Dock's Avatar
Probably because of they provide for quicker wheel changes.
Old 03-20-2019, 02:12 PM
HenryPcar
HenryPcar's Avatar
Proof ?
Old 03-20-2019, 02:21 PM
jdexter
jdexter's Avatar
I don't have any. I'm a surgeon. But guys I know who know a lot about this have told me. ??♂
Old 03-20-2019, 02:26 PM
Dock
Dock's Avatar
https://www.acerracing.com/ACERLug_T...lts-128-1.html
Old 03-20-2019, 03:28 PM
techweenie
techweenie's Avatar
I think a guide pin is the cheaper and easier way around dealing with stock wheel bolts.
And it's not an expensive solution: https://www.ebay.com/itm/1pc-14x1-5-...di/16239877099
Old 03-20-2019, 04:38 PM
powdrhound
powdrhound's Avatar
Received 1,723 Likes on 1,003 Posts
We have found that the H&R studs are the only ones that hold up long term. My shop uses these on all cars used in endurance racing. I would not trust any other studs most most of which have well documented failures. I have run H&R studs on my car with many years of hard track use. Torque to 118ft.lb!
For street cars, I see no benefit of using studs.
Old 03-20-2019, 05:23 PM
s65e90
s65e90's Avatar
95% of street cars come with studs.
Old 03-20-2019, 05:27 PM
powdrhound
powdrhound's Avatar
Yes, and basically 100% of which are press in studs, not screw in. 0% of modern Porsche street cars come with studs. All I'm saying is that studs offer the advantage during frequent wheel changes at the track and that is simply not the case with street driven cars, hence my statement that they do not offer any advantage over OEM lug bolts in street applications.
Quick Reply: Wheel studs or factory wheel bolts
