Lowering the Engine a Couple of Inches
I need to change my oil level sensor. I started to get it from above but my concern is putting the 2 oil filler tube bolts back in the holes without dropping them as well as being unsure if there is clearance to remove the sensor. I spoke to a tech who said you can just drop the engine a couple of inches to give you the clearance to get at the single bolt for the sensor (the upper bolt has the sensor and filler tube, so only that would be needed if it was lowered)
My questions are:
1- has anyone changed this sensor and can give pointers or direct me to a how-to? This is the oil level sensor located at the far back right as you look at the engine, not the oil pressure sensor
2- how do you drop the engine a couple of inches? The tech mentioned there are 2 19s that you undo and I am guessing you remove the air cleaner too. Is that it or are there other items to disconnect?
TIA.
My questions are:
TIA.
Picture shameless borrowed from the interweb, and this isn't a turbo 996 (different exhaust), but these are the motor-mount nuts you are looking for...
My questions are:
TIA.
My questions are:
TIA.
Yes I did. Just take the two nuts off the mount bolts with a jack underneath to lower it. It’s tight, but you can swap it out. A magnetic extension would make this much easier. Don’t drop the bolt! Ask me how I know....
Ipman- how did you remove the bottom bolt? It seem the old filler tube is held by a clamp, but the problem is the filler tube is keyed to a slot below the clamp, so I can’t Move the filler tube to gain access to the bottom bolt.
Thanks!
Thanks!
Ipman I got the lower bolt out using a crow’s foot. How in the world does the oil filler tube slide off the metal mount attached to the secondary air pump?
I am trying to add a GT3 oil dipstick. Did you have to pry the oil filler tube to get it out of the key way? I slid the filler tube towards the rear of the car, then popped it out with a small screwdriver.
