Anyone running Briegestone Potenza RE-71R's?
Edit add: The Michelins are good on wet roads.
I know the question wasn't directed at me, but I have.
I would say the PS2's are slightly quieter, and slightly more comfortable (softer sidewall vs. the Falkens).
However, they are more expensive, and grip at the limit is significantly inferior, IMHO. They also lose more grip as they heat up vs. the Falkens, which handle the heat remarkably well. I would say I shaved a couple seconds off my AutoX times, easily, with the Falkens vs. PS2's, and probably more as the day goes on and the PS2's get hot and squirmy.
So for your intended use (and presumably, budget), I agree the Michelins sound like a good choice.
Personally, I refuse to pay top dollar for multiple-generations-old technology, especially when there is a cheaper option with more grip -- I will support Michelin again when they offer the PS4S in suitable sizes.
I spend the vast majority of my 996 Turbo driving time nowhere near the grip limit, so the low noise, ride comfort, and wet grip give the nod to the Michelins. I don't care how old the design is because they work just fine for my needs.
Yep, I meant that genuinely and not snide in any way. Tires are certainly not a one-size-fits all proposition, which is why it would be nice to have more options.
Michelin's own PS4S is superior in every way (2 generations newer), and no more expensive. That just bothers me, personally. But you're not wrong.
Thanks Dock and Manimal, really great feedback.
I'm still undecided, but I have a few months, less if I decide I can no longer live with AD08Rs' howling. Seems mostly up front too.
My primary use case is weekend warrior canyon and coastal roads...mostly canyons now that I moved from SF to East Bay. I wouldn't call it high speed, but I do love the tight bumpy gravely backroads and I need grip from about 40 degrees up to 90 ambient.
My buddy (MotoJB) just got a new set of GT2 sized wheels for his white Aerokit Turbo, and he's going with the RTK 615+, so I'll get to drive and hear them before I commit. He's currently running the same Yok AD08Rs that I have, but I believe he has about half the miles, so they're not as loud as mine are with 6000 miles on them.
I too would love PS4s or PSSs, but without a 295/30 or 315/30 it's a non-starter. One benefit of high grip low longevity tires like the Yoks and Falkens is that we can try several, and it's not a huge time mileage commitment. I'm very happy to ditch my Yoks at 7500-8000 miles.
-Sean
-Sean
I've been using 235/40r18 and 285/35r18 MPSS. Ran them on the track and as a daily. Totally fine as a daily, increase the rear tire pressure to counter any oversteer from the combination. I switch between them and OEM sized AD08R.
I will probably run 225/285s for the PS4S tires or 235/40 and 295/35 MPSS next.
-Sean
-Sean
I think the Falkens are great for a canyon carver, but at anything less than 9/10th's (hopefully the case in the canyons), the PS2's are great, too.
At $600 a set, I’m going to drive the G-MAX RS like I got them free from a wrong delivery to my address.
Tires howl? Get louder exhaust and put the windows down. I like tires that are more communicative especially at the limits of lateral g. PS2 don’t communicate well to me.
I have a loud exhaust, and I don't like tires competing with or altering its great sound.
P.S. It's hard to maintain a nice interior if you put the windows down when it's raining.
IMO they communicate just fine.
I'm not too worried about the 0.5" difference at all, tire diameter change with wear no way will it be at the "perfect" ratio all the time. Once you renew your rears and keep the fronts, the ratio is off again, can't expect Porsche engineering to not account for that.
Tire technology makes a bigger difference to me than a slight deviation in Revs/km. Haven't seen an major issues in the 2 years i've been running them either.
