is there a mounting kit available? for those using this battery how do you mount, and did you have to lengthen the terminals? or the stock length worked fine?
Definitely a few ways it can be done and some options out there. This is one route you can go as well and the tray will give the base of the battery a Group 48/H6 footprint that will bolt right to the stock mounting cleat on most models. https://antigravitybatteries.com/pro...-adapters-sae/
