Antigravity ATX-30 Battery
#31
Thanks guys,
It's a real good compliment to our turbos for DD duty if you've taken yours a little more track focused.
Took it on some twisties yesterday for the first time and it feels much lighter than it looks, probably because it is.
#32
ATX-30 Update after sitting a couple months
To update this thread, we've had great weather this fall so I ran around with the new battery for a week from 10/7 - 10/15. Commuted 20mi ea way, ran around a bunch for fun while using my headlights all the time and radio some, then let the car sit for a week because I bought a 991s. Went out and started the car right up early this morning, gauge reading 40 degrees after sitting for 6 days, no issues at all during any of this. V reading on Durametric at startup this am:
When I was got out Christmas lights just before Thanksgiving it started no problem after sitting a month. I backed it out, let it idle for 15-20 minutes, revved it up a few times then locked it up until today.
I went to start it and there were no dash lights or interior lights...dead.
Used the jump box below to open both lids and tried the restart button with no luck.
Put the jump box on the engine, started up fine, let warm up for 10 minutes, drove about 5 miles to put in a full tank of 100 where I turned off the car.
It started back up fine so I figured I'd get some drive-thru Taco Hell and let it charge a bit before driving back the 10 minutes to park it for a bit.
When I was looking at the gauges before shutting it off, I did notice the clock was still at the correct time and nothing acted funny while driving it with the lights and heater on,
Will be interesting to see if it starts up fine in a couple days as the weather here looks good Fri-Mon and the car needs a spring cleaning, or at least a hard run or ten.
I've noticed the original battery in my DD 991 had a slow crank a few mornings after sitting in the snow and am tempted to try one as a replacement and loose 30lb up high.
If you're on the fence about using this battery it has my vote.
#33
Premium Sponsor
A few days after this post above(end of October) I parked the car for the winter in an unheated garage with the alarm set.
I thought it was a little small for average use but if it working for you I'm stoked and I like that you got to have a longer storage on it. While I would have liked the RE-START to work, I won't be too bummed for the ATX being its a low Amp Hour Battery and appeared to have a fairly long storage time since Oct. 2018 if I read that correctly. But keep in touch with any data and we'll take care of you if any issue. This is a good test for me to know about since I usually tell people go higher in Amp Hours in the more "passenger type" Cars or longer storage periods. scott@antigravitybatteries.com
Also if you didn't know we have a new Battery that is OEM fit, and has a WIRELESS Keyfob RE-START system.... if you want to try that out in a longer term test in the "S" let me know, I can get you a very deep discount and at the end free if you provide us some longer term data. We have a 24Ah version that could use a some storage and daily driving testing. And at 24Ah... it still lower Ah, but better than and ATX30 and is only 8.6 pounds in the H5 size... or 9/5 in the H6 size. But the cool thing is it has a new Wiresless Remote Jump Starting so you can get your frunk open even if it does over-discharge... simply press the RE-START button on the Remote. Some pictures below...
#34
Appreciate you taking the time to follow up with the ATX30 use. For good or bad, I love hearing about the real world use of the products.
#35
#36
Today I went and started up the car fine after sitting a couple days. The battery seems to be working fine after stopping and restarting several times. Another thing I noticed is that with this battery my stock radio and CD changer don't act funky after having had the battery be dead. With 2 different batteries I had previously, if they went low on juice or dead and had to be recharged, the battery needed to be disconnected then reconnected for the stereo to work.
#37
Thread update:
ATX-30 restart I've been using since 10/18 in my mostly track turbo has performed great, never have had an issue using it as a sporadic DD with stock radio, juiced up headlights and radar.
I've let it die a couple times from lack of use after over a month and the restart button didn't seem to do anything, so used a jumpbox to start the car, then drove around for 15-30 minutes and the battery was fine.
Now days the car typically sits for a week or two, with maybe a short blast around town/hwy, then gets to the track, repeat.
May put one in the 991 when original craps out.
#38
Premium Sponsor
Thread update:
Can you check the voltage after you press the restart button is should have "phantom voltage" around 6v when it goes to sleep sometimes, just energy left in the BMS... or it will show 0v..... but upon clicking the RE-START button it should go back to 13.2v about. It it doesn't then let us know. Maybe the button is not working? But we'll take car of it... should be firing it right up. The ATX 30 is a little tight on capacity but should still fire it up. Let us know, we'll get that correct. So just need to know if the voltage is popping back up. Basically the voltage should cut off if the battery is roughly in the lower 12v range.... then go into sleep mode. Then if you press it should be in the 13s... and be able to start the car. Contact myself scott@antigravitybatteries.com or chad@antigravitybatteries.com
#39
Thanks Scott, I appreciate the support and will test the voltage this week.
I did drive it recently after sitting for about 2 weeks and everything worked fine,
Antigravity (07-26-2019)
#40
In case anyone's wondering about these batteries, I went to the track yesterday and fired up my turbo after about 2 weeks of sitting and this time it was ~40* where stored. Slow crank but fired right up.
Last time I ran it was another 2+ weeks sitting and no issue then either.
I was going to put one in my 991 but then a guy hit my bumper and while in the shop battery went dead so his insurance paid for a brand new P-one.
great product IMO
great product IMO
#41
No wonder you're trying to shed BMWs; what flavor is the 991?
#43
I'm going to keep them both until spring I think, need to fix a valve cover and pan leak in the green one and the silver one has a rebuilt title but impeccable history and tons of new parts making them both hard to part with.
2012.5sPDK with good options
Price; ATX-30rs new for $285 on eBay.
#44
Love the color; nice with the black rims.
#45
